Define Paramenter in ANSYS Workbench and use it as a UDF Variable |
January 29, 2014, 16:16 |
Rafael Cerqueira
Rep Power: 14 |
Is there a way to load a parameter defined in the ANSYS Workbench into my UDF? There's a function called "RP_Get_Real()" that returns a "Scheme variable".What's this "Scheme variable?" Thanks! |
April 1, 2014, 11:30 |
Hi
I have the same problem ;/. Rafacerq, have you found any solution ?? |
April 1, 2014, 12:10 |
Rafael Cerqueira
Rep Power: 14 |
No, i haven't found a solution.
I abandoned the Ansys workbench for my parametric study and created a script with the journal files. |
June 25, 2015, 16:14 |
Found this
Pranab N Jha
Rep Power: 17 |
Guys,
I found this article, might be just what you are looking for. http://www.computationalfluiddynamic...sys-workbench/ |
June 26, 2015, 06:24 |
Rep Power: 12 |
If you want to use WB parameters as input to fluent, you need to use command "Register Startup Scheme file" (Right click on the setup in fluent module in WB schematic). eg. a.scm In a.scm you need to initialize variable and update value from WB. |
