Lift Coefficient vs Angle of Attach for Pitching Airfoil |
January 29, 2014, 03:17 |
Musa
Rep Power: 14 |
Hi Everyone,
I am performing airfoil Pitching in fluent using UDF. I am using this equation alpha = alpha(o)+alpha(a)*sin(Wt) alpha(o) = mean angle of attack (10) alpha(a) = pitching amplitude (15) My problem however is how to plot the lift coefficient vs AOA as shown in the picture below. Normally in the static case, you specify the angle of attack for x and y in fluent and report the forces after simulation for each angle of attack. Which means you have to run a lot of cases if your aoa is between (-5 to 25). However looking at the pitching case and the picture I do not know to plot it. Please any help will be appreciated. Regards Franklyn |
airfoil lift and drag coefficient | amir_14 | FLUENT | 5 | January 1, 2013 08:30 |
Determining Stall Angle of 2D Airfoil | Active.Aero.Fiero | FLUENT | 3 | October 27, 2010 09:07 |
Lift Coefficient of an Airfoil. | pandelis chatzis | Siemens | 2 | September 5, 2002 03:00 |
Lift Coefficient Vs. Angle of Attack | cfd_pro | Main CFD Forum | 1 | August 23, 2002 17:21 |
Highest lift coefficient | Mark Render | Main CFD Forum | 5 | March 2, 2000 08:30 |
