Error on initialisation simulation after implemening UDF
Old   January 10, 2014, 06:21
Default Error on initialisation simulation after implemening UDF
Aileen Magee
0906536m is on a distinguished road
Hello there,
I have been trying to implement the Density and speed of sound UDFs for compressible liquid flows into my model. I use the example given within the UDF manual with my specific values:
Density and speed of sound UDFs for compressible liquid flows.
For use with pressure-based solver, for single phase, multiphase mixture
or cavitation models only.
Note that for density function, dp is the difference between a cell
absolute pressure and reference pressure.
#include "udf.h"
#define BMODULUS 24.32e9
#define rho_ref 2170
#define p_ref 101325
DEFINE_PROPERTY(brinesuperfluid_density, c, t)
real rho;
real p, dp;
real p_operating;
p_operating = 8.04e6;
p = C_P(c,t) + p_operating;
dp = p-p_ref;
rho = rho_ref/(1.0-dp/BMODULUS);
return rho;
DEFINE_PROPERTY(brinesound_speed, c,t)
real a;
real p, dp,p_operating;
dp = p-p_ref;
a = (1.-dp/BMODULUS)*sqrt(BMODULUS/rho_ref);
However, on initialising I get the error:
FLUENT received fatal signal (ACCESS_VIOLATION)
1. Note exact events leading to error.
2. Save case/data under new name.
3. Exit program and restart to continue.
4. Report error to your distributor.
What is wrong in the UDF? Any help would be appreciated!
0906536m is offline   Reply With Quote
Source Term UDF VS Porous Media Model pchoopanya Fluent UDF and Scheme Programming 1 August 28, 2013 07:12
Simulation with UDF for species mass fraction and velocity profile virgy Fluent UDF and Scheme Programming 8 February 7, 2012 05:30
UDF parallel error: chip-exec: function not found????? shankara.2 Fluent UDF and Scheme Programming 1 January 16, 2012 23:14
UDF...UDF...UDF...UDF Luc SEMINEL FLUENT 0 November 25, 2002 05:03
UDF initialisation of DPM model Lasse Rosendahl FLUENT 0 December 11, 2000 10:08
