Fluent 6.3.26 on Linux does not compile an UDF
Old   November 20, 2013, 05:58
Default Fluent 6.3.26 on Linux does not compile an UDF
AFM
Entwistle is on a distinguished road
Hello to everybody;
I have a problem when I try to interpret a very basic UDF (a velocity inlet boudary condition) in Fluent 6.3.26. When I press the "compile" button, fluent show me the next message:
cpp -I"/usr/Fluent.Inc/fluent6.3.26/src" -I"/usr/Fluent.Inc/fluent6.3.26/cortex/src" -I"/usr/Fluent.Inc/fluent6.3.26/client/src" -I"/usr/Fluent.Inc/fluent6.3.26/multiport/src" -I. -DUDFCONFIG_H="<udfconfig.h>" "here is the path of my UDF"
Error: PATH OF MY UDF: line 1: syntax error.
cpp: output pipe has been closed
my .c file is this (as you can see it is very simple:
#include "udf.h"
DEFINE_PROFILE(inlet_x_velocity, thread, position)
real x[ND_ND];
real z; /* Z siempre tiene que ser la coordenada vertical */
face_t f;
begin_f_loop(f, thread)
F_CENTROID(x,f,thread);
z = x[2];
F_PROFILE(f, thread, position) = 0.567*z;
end_f_loop(f, thread)
Well, this happens in Fluent 6.3.26, that is installed on a linux server. I try to compile both, in serial mode and in parallel mode; and it fails in both.
Instead of this, when I try to compile in my W7 (64) workstation, there is no problem and it runs correctly.
Someone could help me, please?
Thank you very much.
Entwistle is offline   Reply With Quote
Old   March 4, 2014, 15:49
Mohammad
m2montazari is on a distinguished road
hi,
the problem is with line endings. in windows the line ending character is different from *nix systems.
so convert line endings with a program like geany or in your linux, delete the line endings to have ONE-line text and then press enter at appropriate locations to have correct form of file.
m2montazari is offline   Reply With Quote
interpreted udf, linux server, problem
looking for a smart interface matlab fluent chary FLUENT 24 June 18, 2021 10:07
Linux Fluent HPC parallel system check failed saad3000 FLUENT 1 January 8, 2021 04:34
UDF in Fluent Andrew Fluent UDF and Scheme Programming 5 March 7, 2016 04:38
Fluent 6.3.26 vs 12.1 and partition method Anorky FLUENT 0 April 27, 2010 11:55
UDF of Zimont model in fluent Z Main CFD Forum 0 February 17, 2005 04:07
