Set velocity to zero?
Old   November 20, 2013, 04:57
Default Set velocity to zero?
Select One...
eneja is on a distinguished road
My problem is the following:
First I solve momentum equation and obtain velocity field (steady state). After that I turn on energy eq. for transient simulation and turn off momentum eq. During my transient simulation (heat transfer) I'd like that the velocity is 0 for a while (there is a condition when this happens), and after that it should be again as it was after steady state calculation.
I would be more than happy if anyone could suggest how to do that!
If this is not possible, is it possible to turn off energy equation, when the condition is fulfilled (but not manually, because it is a parametric analysis, therefore it should be automatically).
eneja is offline   Reply With Quote
change velocity, heat transfer, momentum equation
set velocity of a droplet liping_he FLOW-3D 0 November 20, 2012 10:33
How to set phases with different velocity kbaker CFX 16 May 5, 2012 08:25
can i set the velocity and pressure at the inlet at the same time by UDF minyang.cau FLUENT 0 July 15, 2009 00:14
Velocity in Porous medium : HELP! HELP! HELP! Kali Sanjay Phoenics 0 November 6, 2006 07:10
How to set transient ang velocity? edi ghirardi FLUENT 0 April 12, 2005 10:34
