to separate pressure force and viscous force using udf
Old   November 14, 2013, 06:29
Talking to separate pressure force and viscous force using udf
Yaroslav
ignayars is on a distinguished road
Hi all!
I'm simulate unsteady flow in Fluent and I need write to file pressure force and viscous force on a wall every time step. I'm using UDF in parallel, but my UDF working wrong. After first time step Fluent crashes
UDf code :
DEFINE_EXECUTE_AT_END(compute_forces)
/* Initialiazation */
FILE *out;
real ftx, fpx, fvx;
#if !RP_HOST
Domain * domain;
Thread * thread;
face_t f;
real NV_VEC(A);
real Force_viscous_tot[ND_ND], Force_pressure_tot[ND_ND], Force_tot[ND_ND];
real Force[ND_ND], Force_viscous[ND_ND], Force_pressure[ND_ND];
domain = Get_Domain(1);
thread = Lookup_Thread(domain,9);//wall is 9
N3V_S(Force_viscous_tot,=,0.0);
N3V_S(Force_pressure_tot,=,0.0);
N3V_S(Force_tot,=,0.0);
N3V_S(Force,=,0.0);
#endif //!RP_HOST
#if !RP_HOST
begin_f_loop_int(f,thread)
F_AREA(A,f,thread);
/* Get wall shear force and pressure force on face */
N3V_VS(Force_viscous,=,F_STORAGE_R_N3V(f,thread,SV _WALL_SHEAR),*,-1.0);
N3V_VS(Force_pressure, =, A, *, F_P(f,thread));
/* Add forces */
N3V_VV(Force, =, Force_viscous, +, Force_pressure);
/* Accumulate viscous/pressure forces */
N3V_V(Force_viscous_tot, +=, Force_viscous);
N3V_V(Force_pressure_tot, +=, Force_pressure);
N3V_V(Force_tot, +=, Force);
end_f_loop_int(f,thread);
ftx = Force_tot[0];
fpx = Force_pressure_tot[0];
fvx = Force_viscous_tot[0];
#endif //!RP_HOST
#if RP_NODE
ftx = PRF_GRSUM1(ftx);
fpx = PRF_GRSUM1(fpx);
fvx = PRF_GRSUM1(fvx);
#endif //RP_NODE
node_to_host_real_3(ftx, fpx, fvx);
#if !RP_NODE
out = fopen("data.txt","a");
fprintf(out,"%13.5e\t%13.5e\t%13.5e\t%13.5e\n",CUR RENT_TIME,fpx,fvx,ftx);
fclose(out);
#endif //!RP_NODE[/INDENT]}
Thank you!
ignayars is offline   Reply With Quote
Old   October 19, 2014, 08:26
Kuldip Kulkarni
kuldip is on a distinguished road
Originally Posted by ignayars View Post
Hi all!
UDf code :
FILE *out;
real ftx, fpx, fvx;
#if !RP_HOST
Domain * domain;
Thread * thread;
face_t f;
real NV_VEC(A);
N3V_S(Force,=,0.0);
#endif //!RP_HOST
#if !RP_HOST
F_AREA(A,f,thread);
/* Add forces */
ftx = Force_tot[0];
#endif //!RP_HOST
#if RP_NODE
#endif //RP_NODE
#if !RP_NODE
fclose(out);
Thank you!
Hi ignayars,
Please define macro for unsteady simulation before #if !RP_HOST.
You have to define
real current_time;
current_time = CURRENT_TIME;
It may work.
kuldip is offline   Reply With Quote
how does Fluent calculate the pressure and viscous force ? e30.lsb FLUENT 7 June 27, 2011 22:31
Viscous force and coefficient viscous force tobino Main CFD Forum 0 February 20, 2011 22:06
how does Fluent calculate the pressure and viscous force vector? Ralf Schmidt FLUENT 2 May 17, 2010 16:49
pressure force and viscous force CFD FLUENT 0 March 7, 2006 02:03
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 06:13
