Define- mass
Like Tree2Likes
Old   November 22, 2013, 04:46
mehdimoradi
mehdimoradi. is on a distinguished road
Hi
I can interpret without error. but during initializing appear the error:
FLUENT received fatal signal (ACCESS_VIOLATION)
1. Note exact events leading to error.
2. Save case/data under new name.
3. Exit program and restart to continue.
4. Report error to your distributor.
Although i can Compil it completely but in interaction box donot exist any UDF and fluent give the error:
no udf have been loaded.
Have you suggestion, kindly?
mehdimoradi. is offline   Reply With Quote
Old   November 22, 2013, 05:00
pakk will become famous soon enough
From Fluent help:
In order to hook a DEFINE_MASS_TRANSFER UDF to FLUENT, you must first issue the TUI command solve/set/expert and enter no at the Linearized Mass Transfer UDF? prompt.
You did that? Otherwise I have no idea.
pakk is offline   Reply With Quote
Old   November 22, 2013, 05:17
mehdimoradi
Originally Posted by pakk View Post
From Fluent help:
I just didnot notice. please explain it more. how can i access to TUI?
Old   November 22, 2013, 05:59
Mohsen
smhosseini is on a distinguished road
If I try to compile your code, I see
test.c
..\..\src\test.c(5) : error C2146: syntax error : missing ')' before identifier 'om_index'
..\..\src\test.c(5) : error C2061: syntax error : identifier 'om_index'
..\..\src\test.c(5) : error C2059: syntax error : ';'
..\..\src\test.c(5) : error C2059: syntax error : ','
..\..\src\test.c(5) : error C2059: syntax error : ')'
Done.
If I try to interpret it, I see
Error: .\test.c: line 5: parse error.
Don't you get similar lines when you try it? They give hints about what is wrong.
Hi Dear Pakk,
The UDF make error because of writing fr om_index
instead of from_index.
I compiled it and that was the only problem.
smhosseini is offline   Reply With Quote
Old   November 22, 2013, 11:31
Originally Posted by smhosseini View Post
Hi Dear Pakk,
The UDF make error because of writing fr om_index instead of from_index.
So keep an eye on those error messages, they give information about where the mistake can be!
Old   June 27, 2014, 03:03
Default setting Solve/Set/Expert in Ansys 14.5
  #26
djn
Dhananjaya
djn is on a distinguished road
Can you please help me setting it in ansys 14.5 ... I dont have Set or Expert in Solve link...
Also I am using DEFINE MASS TRANSFER .. but by default ansys has linearized mass transfer... I basically want to change it in Solve/Set/Expert
Please Help,
djn is offline   Reply With Quote
Old   July 26, 2014, 13:24
Jackson Sim
reformat is on a distinguished road
hi Djn
To access the TUI in fluent, once your fluent programme is up, key "enter" at the main page. from there, you can then access the tui command.
reformat is offline   Reply With Quote
Old   August 23, 2014, 10:47
Default hamed.moradkhani@yahoo.com
  #28
sarighulikhan
hane is on a distinguished road
do this procedure:
1.define->user-defined->functions->interprated..
interprate the ().c file
2.type on the command window of fluent
solve(press enter)
set(press enter)
expert(press enter)
answer for the 4 comming questions respectively are:
no-yes-no-yes
after these 2 steps u can hook the udf from phase intraction->mass tab->user defined->selecting udf...
now you can start runing calculation
let me inform about ur results
tanx
Hesam_Ami likes this.
hane is offline   Reply With Quote
Old   June 20, 2016, 18:42
SHUJAN
MDSHUJAN is on a distinguished road
Originally Posted by hane View Post
do this procedure:
solve(press enter)
set(press enter)
expert(press enter)
no-yes-no-yes
tanx
Hi. I try your method for hooping a DEFINE_MASS_TRANSFER udf for heta pipe simulation. The udf build and load successfully, but i can't hook it at the phase interaction tab.
Any help is highly appreciated.
MDSHUJAN is offline   Reply With Quote
mass flow inlet and pressure outlet with target mass flow rate Zigainer FLUENT 13 October 26, 2018 06:58
using define mass transfer udf for cavitation Komon Fluent UDF and Scheme Programming 14 June 21, 2016 03:50
Robin B.C. Yu FLUENT 3 May 27, 2012 05:19
UDF problem libia87 Fluent UDF and Scheme Programming 1 May 4, 2012 22:49
DEFINE MASS TRANSFER Maciej FLUENT 0 November 27, 2005 21:33
