September 30, 2013, 10:55 |
UDF Error
I am solving a 2D Axisymmetric Problem . why does it give the below stated error "Error ivergence detected in AMG Solver-X momentum , Error Object: #f " when i attempt to solve viscosity as the function of temp?
for the same problem, when viscosity is constant it solves. can you please give suggestions to solve the problem ? |
September 30, 2013, 11:58 |
Alex
Rep Power: 49 |
First step would be to post the code here
September 30, 2013, 14:15 |
A-A Azarafza
Rep Power: 14 |
Hi!
First, be sure that you defined x axis as axisymmetric axis. This is very common in most 2d axisymmetric geometry. check the values for initialization. You must use reasonable values for interest equation. I suggested this supposedly that the UDF is OK. Good luck
Regard yours |
fluent, udf |
[OpenFOAM] an error in Calculator's equation | immortality | ParaView | 12 | June 29, 2021 01:10 |
Undeclared Identifier Errof UDF | SteveGoat | Fluent UDF and Scheme Programming | 7 | October 15, 2014 08:11 |
ParaView for OF-1.6-ext | Chrisi1984 | OpenFOAM Installation | 0 | December 31, 2010 07:42 |
Installation OF1.5-dev | ttdtud | OpenFOAM Installation | 46 | May 5, 2009 03:32 |
Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 21:50 |
