Di Felice drag model FLUENT UDF
Old   September 11, 2013, 02:51
Default Di Felice drag model FLUENT UDF
Musango Lungu
Musa is on a distinguished road
I am modeling gas solid fluidized beds using different drag models. The Di Felice drag model I used compiles properly but it cannot predict fluidization in the bed. The bed does not fluidize. The code is given below. Any suggestions or advice?
#include "udf.h"
#define pi 4.*atan(1.)
DEFINE_EXCHANGE_PROPERTY(EMMS_Bubbling,cell,mix_th read,s_col,f_col)
Thread *thread_g, *thread_s;
real x_vel_g, x_vel_s, y_vel_g, y_vel_s, abs_v, slip_x, slip_y,
rho_g, rho_s, mu_g, reyp, Res,Cd,X,vof_g, vof_s,taup, k_g_s, diam2;
/* find the threads for the gas (primary) */
/* and solids (secondary phases) */
thread_g = THREAD_SUB_THREAD(mix_thread, s_col);/* gas phase */
thread_s = THREAD_SUB_THREAD(mix_thread, f_col);/* solid phase*/
/* find phase velocities and properties*/
x_vel_g = C_U(cell, thread_g);
y_vel_g = C_V(cell, thread_g);
x_vel_s = C_U(cell, thread_s);
y_vel_s = C_V(cell, thread_s);
slip_x = x_vel_g - x_vel_s;
slip_y = y_vel_g - y_vel_s;
rho_g = C_R(cell, thread_g);
rho_s = C_R(cell, thread_s);
mu_g = C_MU_L(cell, thread_g);
diam2 = C_PHASE_DIAMETER(cell, thread_s);
/*compute slip*/
abs_v = sqrt(slip_x*slip_x + slip_y*slip_y);
/*compute Reynold's number*/
reyp = rho_g*abs_v*diam2/mu_g;
/* compute particle relaxation time */
vof_g = C_VOF(cell, thread_g);/* gas vol frac*/
vof_s = C_VOF(cell, thread_s);/* particle vol frac*/
Res = vof_g * reyp;
Cd=pow((0.63+4.8*sqrt(1/Res),2);
X = 3.7-0.65*exp(-pow(1.5-log10(Res),2)/2);
/* Di Felice Model */
k_g_s = 3/4*Cd*vof_g*vof_s*rho_g*abs_v/diam2*pow(vof_g,-X);
return k_g_s;
Musa is offline   Reply With Quote
Old   November 25, 2013, 04:20
Prashant Gupta
Prash is on a distinguished road
Hi Musa,
Did you find the minimum fluidization velocity using De Felice ?
I suggest take up a case from literature, with a known minimum fluidization velocity. and compare with the solution you are getting.
Alternatively, you could simple test set ups like single particle sedimentation, and block of constant particles falling to check against analytical solutions.
I am also testing these, with EDEM-Fluent.
Kind regards
Prashant
Prash is offline   Reply With Quote
drag coefficient in ansys fluent 12.0 krishna FLUENT 19 April 12, 2018 01:49
problem with UDF for (v2-f) turbulence model in fluent artemiss1984 Fluent UDF and Scheme Programming 6 January 17, 2014 06:50
new turbulence model in Fluent C.C FLUENT 0 August 29, 2013 11:44
fluent udf problem: write specific data for every iteration in a file. nnvoro Fluent UDF and Scheme Programming 1 May 27, 2013 16:26
Advanced Turbulence Modeling in Fluent, Realizable k-epsilon Model Jonas Larsson FLUENT 5 March 13, 2000 04:27
