How to inject DPM particles using DEFINE_EXECUTE_AT_END(name) ?
Old   September 3, 2013, 21:53
Default How to inject DPM particles using DEFINE_EXECUTE_AT_END(name) ?
bawammo is on a distinguished road
Dear all,
I'm using DEFINE_EXECUTE_AT_END(name) to calculate the mass to be injected.
I'm performing the calculations in each time and on each cell.
I need to inject solid particles at each end of calculation if the mass resulted from this calculations is higher than 0.
This is my code:
#include "udf.h"
DEFINE_EXECUTE_AT_END(injection_1)
Domain *d;
Thread *t;
cell_t c;
float mass_to_inject;
real centroid_cell[ND_ND]; /* to capture centroid coordinates of the cell */
d = Get_Domain(1);
thread_loop_c(t,d)
begin_c_loop(c,t)
mass_to_inject = ...; /* some calculations are made here */
if(mass_to_inject > 0)
C_CENTROID(centroid_cell,c,t) /* captures centroid coordinates of current cell */
/* I need to inject the mass of solid particles (or equivalent flow rate):
diameter: 1 mm; temperature: 373.15 K; velocity: 0.1 m (only X direction); density: 1500 kg/m³;
position: X = centroid_cell[0], Y = centroid_cell[1], Z = centroid_cell[2] */
end_c_loop(c,t)
Muchas gracias!!!
bawammo is offline   Reply With Quote
Old   October 30, 2017, 14:20
Pengze Yang
Pengze Yang is on a distinguished road
Have you by any chances got the solution? I run into similar problem.
Pengze Yang is offline   Reply With Quote
UDF for deleting particles in DPM imanmirzaii Fluent UDF and Scheme Programming 12 November 25, 2020 20:27
Injection of specific number of particles in DPM DH FLUENT 12 March 16, 2016 22:04
Fluent DPM deleting particles during iteration civilcfd FLUENT 0 August 7, 2013 12:53
DPM for steady flow with unsteady particles tracking yahya FLUENT 0 March 28, 2013 14:28
DPM - do the particles affect the liquid? Nikhil Dani FLUENT 0 January 1, 2009 12:58
