non-integer subscript expression: float
Old   August 20, 2013, 07:59
Default non-integer subscript expression: float
vExus is on a distinguished road
Being a total rookie at programming I am trying to set free steam temperature as a function of flow time. While interpreting UDF i get this error:
This is how the error line looks like:
F_PROFILE(f, thread, index) = tab[s];
Whole code:
#include "udf.h"
DEFINE_PROFILE (T_ot, thread, index)
	real s;
	double tab[8547]={}; //There are 8547 temperature values set in the correct order (as they change with every time step). I had to cut them off to make the code shorter
	face_t f;
	s=RP_Get_Real("flow-time");
	begin_f_loop(f, thread)
	end_f_loop(f, thread);
While changing "tab[s]" to "tab[2]" UDF interprets fine so "s" must be the problem.
How else can I specify array index? Does code look ok?
EDIT
I have changed "real s" to "int s" and now fluent do interpret UDF.
Does the rest looks fine?
vExus is offline   Reply With Quote
Old   August 20, 2013, 10:16
blackmask will become famous soon enough
You might need to change the code if the index of tab corresponds to time step rather than flow time. Also you need to avoid index out of range.
#include "udf.h"
        int s;
        real tval;
        face_t f;
        s = N_TIME;
        tval = s < 8547 ? tab[s] : tab[8546];
                F_PROFILE(f, thread, index) = tval;
blackmask is offline   Reply With Quote
Old   August 21, 2013, 19:41
Thanks a lot!
array, flow, index, time
How to install CGNS under windows xp? lzgwhy Main CFD Forum 1 January 11, 2011 19:44
CGNS lib and Fortran compiler manaliac Main CFD Forum 2 November 29, 2010 07:25
Missing math.h header Travis FLUENT 4 January 15, 2009 12:48
Lift, Drag Vs time chart,calculations Jamesd69climber CFX 8 February 17, 2005 18:23
to correct me an udf program farida hamadi FLUENT 0 December 18, 2004 06:54
