UDF compiled problem
Old   August 11, 2013, 08:30
Default UDF compiled problem
Enrico Di Cesare
Enricodex is on a distinguished road
Hello to everyone.
I am new in this forum. I am an italian mechanical engineer and i'd like to learn deeply Fluent .
So i am trying to make the help tutorials, and in particulary the 15th (" Using Dynamic Mesh").
When I try to compile the UDF file the console says to me that there are problems. So seeing the working folder I found a txt file named CORTEXERROR where is written :
"Error [cortex] [time 8/11/13 13:14:34] The UDF library you are trying to load (libudf) is not compiled for 2ddp on the current platform (win64)".
I am probably able to figured out which is the problem but I am not sure and I 'd like to hear the opinion of someone else more expert than me.
Thanks to everyone that wanted help me and have a good Sunday
Enricodex is offline   Reply With Quote
Old   August 11, 2013, 18:22
Stephan Langenberg
Jim87 is on a distinguished road
I had this and related errors several times.
For myself I find the easiest and best working UDF activation on Windows using this steps:
1. Case and UDF in the same domain
2. open a console and compiling the UDF with standard Windows command
3. Starting Fluent by console
4. defining UDF Libary and compile -> Load
5. activating UDF
- This steps might seem not perfect or not practible for every user (non-windows, natchfile etc.) But I made good experience with using the windows console in this sizes.
P.S: Not compiled is a direct hint. First compile every UDF, the UDF should have a +.c ending.
Jim87 is offline   Reply With Quote
Old   August 11, 2013, 18:48
Enrico Di Cesare
Thanks Jim
I found a discussion in UDF forum that have helped me to fix the problem.
In my laptop was installed Microsoft Visual 2005 and It was too old. So I downloaded the 2010 Version and I followed the same step that you have just adviced to me.
And everything works.
That's cool
Bye
Mesh UDF problem kornetka Fluent UDF and Scheme Programming 4 July 25, 2013 07:54
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 05:43
problem with udf for dynamic mesh ja92 FLUENT 0 February 24, 2011 10:32
Help! Compiled UDF problem 4 Wave tank tutorial Shane FLUENT 1 September 3, 2010 03:32
UDF variables F1, y / problem with UDF Fabian FLUENT 6 June 2, 2003 11:22
