August 7, 2013, 12:56 |
UDF wall function
Davide
Rep Power: 14 |
Hi all,
i'm doing a simulation with fluent (v14); given the small domain, and the "slow" inlet velocity profile, i've used k-epsilon model with Enhanced wall treatment turned on; yplus is 1 (more or less). The results are good, in some way. I would like to improve these results. Is there any other option i could activate to improve it? Or is there any UDF wall function out there? My experience with wall functions is pretty limited, so if someone could help me, please! |
udf wall function |
[blockMesh] non-orthogonal faces and incorrect orientation? | nennbs | OpenFOAM Meshing & Mesh Conversion | 7 | April 17, 2013 06:42 |
OpenFOAM static build on Cray XT5 | asaijo | OpenFOAM Installation | 9 | April 6, 2011 13:21 |
ParaView for OF-1.6-ext | Chrisi1984 | OpenFOAM Installation | 0 | December 31, 2010 07:42 |
Error with Wmake | skabilan | OpenFOAM Installation | 3 | July 28, 2009 01:35 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 18:51 |
