August 5, 2013, 13:00 |
How to locate all the edge node by UDF?
Edison
Rep Power: 17 |
Hi, I want to implement Womersley velocity profile on inlet of a 3D vessel. However, the inlet face is not strictly a circle, so I need to map a profile for circle to the non-regular inlet face. The implementation involves finding the nodes on the edges of inlet face, which means the nodes on the vessel inlet and vessel wall.
I am wondering if there are any Fluent udf macro can do this or how to write a code to locate (get the coordinate) all the edge nodes? Thank you in advance. Last edited by hadesmajesty; August 5, 2013 at 16:29. |
August 7, 2013, 04:52 |
Paritosh Vasava
Rep Power: 23 |
Have a look at macro C_FACE.
Also look at these pages http://www.sharcnet.ca/Software/Flue...udf/node94.htm |
How to get the Global Node Number by UDF : Fluent | Yusuke | FLUENT | 1 | October 23, 2015 11:55 |
UDF parallel error: chip-exec: function not found????? | shankara.2 | Fluent UDF and Scheme Programming | 1 | January 16, 2012 23:14 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 12:55 |
I need UDF help. | S.Whitney | FLUENT | 0 | October 15, 2007 12:29 |
Node values on UDF??? | Kamal | FLUENT | 1 | December 10, 1999 11:37 |
