UDF : velocity, k and epsilon (radial profile)
Old   July 23, 2013, 07:02
cdiako is on a distinguished road
It's really strange, I have compiled the udf and the compiler tells me this :
udf_final_velocity_check.c: In function ‘some_func’: udf_final_velocity_check.c:6: warning: excess elements in array initializer udf_final_velocity_check.c:6: warning: (near initialization for ‘r0’) udf_final_velocity_check.c:7: warning: excess elements in array initializer udf_final_velocity_check.c:7: warning: (near initialization for ‘v0’) udf_final_velocity_check.c:5: warning: unused variable ‘vel’ udf_final_velocity_check.c: In function ‘inlet_axial_velocity’: udf_final_velocity_check.c:23: warning: unused variable ‘v’ # Linking libudf.so because of makefile user.udf udf_names.c udf_names.o udf_final_velocity_check.o ld -shared -lm udf_names.o udf_final_velocity_check.o -o libudf.so make[3]: warning: Clock skew detected. Your build may be incomplete. make[3]: Leaving directory `/home/cdiakodi/Desktop/Fluent_fran_fran/maillage_pr_fluent/new_2/lnamd64/3d' make[2]: warning: Clock skew detected. Your build may be incomplete. make[2]: Leaving directory `/home/cdiakodi/Desktop/Fluent_fran_fran/maillage_pr_fluent/new_2/lnamd64/3d' make[1]: warning: Clock skew detected. Your build may be incomplete. make[1]: Leaving directory `/home/cdiakodi/Desktop/Fluent_fran_fran/maillage_pr_fluent/new_2/lnamd64/3d'
an idea ?
cdiako is offline   Reply With Quote
Old   July 26, 2013, 21:42
blackmask will become famous soon enough
It happens if you the array initializer has more elements than the array declared
int r0[3] = {0, 1, 2, 3};
In the above example "r0" is an integer array of length three while the initializer has four elements. In my post I wrote it as
int r0[] = {0, 1, 2, 3};
There should be no warning.
blackmask is offline   Reply With Quote
Old   July 29, 2013, 05:44
You were right, the UDF works now.
Thank you!
Old   July 30, 2013, 09:29
Just one last question: how can I change the UDF that we have created to add a velocity profile of particles (using DPM)?
UDF for inlet velocity profile Bollonga Fluent UDF and Scheme Programming 4 June 29, 2021 05:40
SimpleFoam k and epsilon bounded nedved OpenFOAM Running, Solving & CFD 16 March 4, 2017 09:30
UDF to define velocity, k, epsilon profiles at velocity-inlet aerospain FLUENT 0 July 8, 2011 08:14
SimpleFoam k and epsilon bounded nedved OpenFOAM Running, Solving & CFD 1 November 25, 2008 21:21
UDF velocity profile problem Steve FLUENT 0 January 18, 2005 13:11
