Re: Strange Problem in Temperature Contour, continuity residual
Old   June 27, 2013, 10:17
Default Re: Strange Problem in Temperature Contour, continuity residual
Yash Ganatra
yashganatra is on a distinguished road
I am working on a melting problem. By default FLUENT solves Energy eqn in terms of enthalpy so I have written a User Defined Scalar to solve for temperature. However, while doing so, the continuity residuals are beahving strangely.
Boundary Condition:
Left wall : 310K
Right Wall : 290 K
Top & Bottom : Adiabatic
On seeing the temperature contours, I am noticing something very strange and unrealistic. They max value is above 310 K!! This is an unrealistic solution and I am trying to figure out the cause.
Kindly give your suggestions.
Something has gone terribly wrong!!!
Regards,
Yash
File Type: jpg Temperature(NOTE 323K temperature reading).JPG (47.6 KB, 21 views)
yashganatra is offline   Reply With Quote
continuity residual, fluent 13, temperature contours, temperature problem, user defined scalar
alphaEqn.H in twoPhaseEulerFoam cheng1988sjtu OpenFOAM Bugs 15 May 1, 2016 17:12
Velocity blows up suddenly after 30,000+ iterations lordvon OpenFOAM Running, Solving & CFD 15 October 19, 2015 14:52
Sudden jump in Courant number NJG OpenFOAM Running, Solving & CFD 7 May 15, 2014 14:52
ForcesCoeffs ronaldo OpenFOAM 4 September 14, 2009 08:11
Negative value of k causing simulation to stop velan OpenFOAM Running, Solving & CFD 1 October 17, 2008 06:36
