UDF to iterate momentum source for desired flow
Old   June 19, 2013, 16:06
Default UDF to iterate momentum source for desired flow
Chris Tyler
chtyler is on a distinguished road
I'm pretty much a newbie with Fluent, so please forgive what may be a simple question. I have a model with a momentum source to set a recirculation rate. I'd like to write a UDF to adjust the momentum source in a transient simulation to get the desired recirculation rate. I cannot, however, find the appropriate macro to set the momentum source. Can someone point me in the right way?
Regards,
Chris
chtyler is offline   Reply With Quote
Old   June 20, 2013, 03:41
Yash Ganatra
yashganatra is on a distinguished road
Try out DEFINE_SOURCE macro. An example is give in the UDF Manual
yashganatra is offline   Reply With Quote
momentum source
Momentum source coefficient, cylindrical coordinates, circumferential component? polakse CFX 15 January 18, 2016 03:40
Source Term UDF VS Porous Media Model pchoopanya Fluent UDF and Scheme Programming 1 August 28, 2013 07:12
[swak4Foam] Error bulding swak4Foam sfigato OpenFOAM Community Contributions 18 August 22, 2013 13:41
Mass source, Momentum source theory. diffo FLUENT 4 August 21, 2009 11:26
Problem with Mass source, Momentum source theory diffo Fluent UDF and Scheme Programming 0 August 20, 2009 07:10
