June 16, 2013, 05:02 |
Declation of a vector in a UDF
I am having some troubles with the declaration of a vector in a UDF. The UDF is used for varying the time step. The vector is using for describing this variation. In this exemple, I want a first time step of 1, then of 5, then of 2 and finally of 4 for having successively a flow time of 1, 6, 8, 12. So, I declare the vector by this way : V[3]=(1, 5, 2, 4); And then I use a for loop by this way where dt is the time step: for(i=0; i<=3; i++) {dt=V[i];} The problem is that I didn't have the except result. I have successively a flow time of 4, 8, 12, 16. I think that only the last coordinate of the vector is taken into account. The resulting flow time is the last coordinate, two time the last coordinate, ect. So, I suppose that I incorrectly declare the vector. In the bracket, I define the vector dimension and in the parenthesis I define the coordinates of the vector. Can someone explain me how to declare a vector for my purpose ? Thanks in advance. |
Dynamic Mesh UDF | Qureshi | FLUENT | 7 | March 23, 2017 08:37 |
UDF parallel error: chip-exec: function not found????? | shankara.2 | Fluent UDF and Scheme Programming | 1 | January 16, 2012 23:14 |
How to add a UDF to a compiled UDF library | kim | FLUENT | 3 | October 26, 2011 22:38 |
UDF...UDF...UDF...UDF | Luc SEMINEL | FLUENT | 0 | November 25, 2002 05:03 |
UDF, UDF, UDF, UDF | Luc SEMINEL | Main CFD Forum | 0 | November 25, 2002 05:01 |
