Computing surface normal gradient at boundary |
June 12, 2013, 22:53 |
mandeep
Dear all,
i am trying to write udf for grid motion.i need to know the component of the concentration gradient in the direction normal to the moving boundary. to take into account the mesh non orthogonality fluent computes the gradient component in the normal direction as ((phi1-phi0)/ds)*(A.A)/A.es + cross diffusion term the second term can be evaluated using a macro " boundary secondary gradient source". my doubt is with first term (A.A)/A.es , ds can be found using macro "boundary face geometry". but phi 1 for a boundary face is not defined. for internal face phi 1 ,phi 0 represent the value of scalar (conc in this case)at cell on either side of face. SHOULD I USE THE VALUE AT FACE CENTRE FOR PHI1? ALSO IN THAT CASE WHETHER I SHOULD USE PHIFACE-PHI0 OR PHI0-PHIFACE ANY KIND OF HELP IS HIGHLY APPRECIATED thanks |
Radiation interface | hinca | CFX | 15 | January 26, 2014 18:11 |
Water subcooled boiling | Attesz | CFX | 7 | January 5, 2013 04:32 |
[snappyHexMesh] Add additional boundary layers to complex stl surface | tobijingles | OpenFOAM Meshing & Mesh Conversion | 1 | October 26, 2011 11:45 |
[Gmsh] Import problem | ARC | OpenFOAM Meshing & Mesh Conversion | 0 | February 27, 2010 11:56 |
[CAD formats] my stl surface is seen as just a line | rcastilla | OpenFOAM Meshing & Mesh Conversion | 2 | January 6, 2010 02:30 |
