souce term-error in both "interpreting and compiling" |
June 10, 2013, 08:39 |
Moha
when I interpreting the code I receiving :
two "parse error" for the highlighted lines . what is wrong in the code? Code:
#include "udf.h" DEFINE_SOURCE(energy_udf,c,t,dS,eqn) { real source; if(N_TIME > 0) { if (C_T(c,t) > C_T_M1(c,t)) { if (C_T_(c,t)<=297. && C_T(c,t)>=287.) { source =(-0.0235*pow(temp,3.))+(20.246*pow(temp,2.))-(5816.7*pow(temp,1.))+557045; dS[eqn] =(-0.0705*pow(temp,2.))+(40.492*pow(temp,1.))-5816.7 ; } } else if (C_T(c,t) < C_T_M1(c,t)) { if (C_T_M1(c,t) <= 285.0 && C_T(c,t) >= 297.0) { source =(-0.0227*pow(temp,3.))+(19.483*pow(temp,2.))-(5568.7*pow(temp,1.))+530603; dS[eqn] =(-0.0681*pow(temp,2.))-(38.966*pow(temp,1.))-5568.7; } } } return source; } ..\..\src\test.c(36) : warning C4003: not enough actual parameters for macro 'C_T_' ..\..\src\test.c(36) : error C2059: syntax error : ')' ..\..\src\test.c(51) : error C2059: syntax error : 'return' ..\..\src\test.c(52) : error C2059: syntax error : '}' any helps ? |
