Fluent & N_UDMI
Old   May 29, 2013, 03:46
Default Fluent & N_UDMI
benjamin_ is on a distinguished road
Hello everybody
I'm experiencing difficulties to correctly use N_UDMI's.
I have my UDF which writes on some mesh nodes UDMI's.
Still with Fluent opened, I can see the values of my N_UDMIS (by ploting their contours).
So I save *.case and *.data
But when I close Fluent and when I re-open the *.case and *.data, my UDMI's are still declared, but all their values are reset to 0.
I dont understand the issue...
Maybe related, when I open the *.case and *.data , I have this message displayed :
Allocated User-Defined Node Memory (10 locations) does not match data file (16 locations) !
which I dont undestand because I only declare 10 UDMI's
benjamin_ is offline   Reply With Quote
Old   May 29, 2013, 04:11
Default OK
OK , I just realize that I only use 9 N_UDMI's in my UDF, so I only have to declare 9 UDMI !!
Quiet surprising we necessarily have to declare the exact number of UDMI's we use !
Connecting Fluent benefits and Injection Molding Software Jim87 FLUENT 1 August 6, 2023 17:06
Two questions on Fluent UDF Steven Fluent UDF and Scheme Programming 7 March 23, 2018 04:22
heat transfer with RANS wall function, over a flat plate (validation with fluent) bruce OpenFOAM Running, Solving & CFD 6 January 20, 2017 07:22
Alias problem when starting FLUENT from command line batch_error FLUENT 0 May 24, 2012 09:20
Problems in lauching FLUENT Lourival FLUENT 3 January 16, 2008 17:48
