UDF creating a pulse input
Old   May 24, 2013, 20:04
Exclamation UDF creating a pulse input
Megan Wood
mwood is on a distinguished road
Hello
I am trying to create a pulse input to represent my system ideally it would have a 30min pulse every 24hrs. I have a 'line 1: parse error'
and I can't seem to figure it out
This is my code:
# include "udf.h"
DEFINE_PROFILE(velocity_magnitude, t, i)
real velocity;
real the_current_time;
face_t f;
the_current_time = CURRENT_TIME;
if ((the_current_time>=0) && (the_current_time<1800))
velocity=3;
if ((the_current_time>=86400) && (the_current_time<88200))
velocity=3;
if ((the_current_time>=172800) && (the_current_time<174600))
velocity=3;
else
velocity=0
begin_f_loop(f,t)
F_PROFILE(f,t,i) = velocity;
end_f_loop(f,t)
Any help would be much appreciated.
Thanks
Megan
mwood is offline   Reply With Quote
Old   May 24, 2013, 21:47
blackmask will become famous soon enough
Remove the space between # and include in the first line and try again.
blackmask is offline   Reply With Quote
Old   May 24, 2013, 21:50
Megan Wood
Hey,
Thanks!
However, no such luck.
Any other ideas?
Old   May 24, 2013, 22:56
See this thread (http://www.cfd-online.com/Forums/flu...e-error-2.html).
Old   May 26, 2013, 19:20
Megan Wood
no luck with that thread either. If it were saved in the wrong spot would that cause this error?
Old   May 28, 2013, 09:20
soodabe
borhan_sd@yahoo.com is on a distinguished road
Hi all ,I’m new in fluent and particularly UDF, I want to model a system that a gas is inlet and it flows for 3s and doesn’t flow for 3s alternatively and continuously. In fact it’s our respiration flow and the model is a respiratory mask.
How should I write UDF file? Probably CURRENT_TIMESTEP Macro should be used, Is it right?
Would you tell me please how should I write the UDF? This is very important for me.
Thank you very very much in advance.
borhan_sd@yahoo.com is offline   Reply With Quote
parse error, pulse input, udf, varying velocity
UDF parallel error: chip-exec: function not found????? shankara.2 Fluent UDF and Scheme Programming 1 January 16, 2012 23:14
How to add a UDF to a compiled UDF library kim FLUENT 3 October 26, 2011 22:38
Help Parallelizing UDF AndresC FLUENT 0 February 25, 2010 16:50
Tablular values as input to UDF BS FLUENT 0 March 30, 2008 19:59
UDF, UDF, UDF, UDF Luc SEMINEL Main CFD Forum 0 November 25, 2002 05:01
