June 6, 2016, 07:19 |
#21 |
Rep Power: 27 |
Not an error per se, but something that could be simplified:
if ( t <= 100.0 ) { F_PROFILE(f,thread,position) = 379.48 + 0.0004*t; } else if (100.0 < t && t <= 180.0 ) ... Code:
if ( t <= 100.0 ) { F_PROFILE(f,thread,position) = 379.48 + 0.0004*t; } else if (t <= 180.0) ... For the rest: you should tell us if there are errors, or if the udf does not do what you want. We can not guess that. |
June 6, 2016, 10:40 |
#22 |
mm
Rep Power: 9 |
Thank you so much for your help.
there is no error uptill now. further i can check when simulations proceed further. as i am modelling 3d with very fine mesh, so its very slow simulation. Regards |
June 6, 2016, 11:03 |
#23 |
Rep Power: 27 |
If you want to test this UDF quickly, you can consider to use a smaller mesh.
Dynamic Mesh UDF | Qureshi | FLUENT | 7 | March 23, 2017 08:37 |
USING IF statement in a UDF for defining Velocity profile at Inlet | amir2920 | Fluent UDF and Scheme Programming | 3 | May 24, 2013 00:46 |
UDF parallel error: chip-exec: function not found????? | shankara.2 | Fluent UDF and Scheme Programming | 1 | January 16, 2012 23:14 |
[Commercial meshers] ST_Malloc: out of memory.malloc_storage: unable to malloc Velocity SA, | cfdproject | OpenFOAM Meshing & Mesh Conversion | 0 | April 14, 2009 16:45 |
UDF "AND" Statement | Curtis | FLUENT | 1 | December 11, 2002 22:34 |
