udf velocity profile
Old   May 20, 2013, 15:47
Unhappy udf velocity profile
hilla tor
hillat is on a distinguished road
hi I am trying to write a udf function that use the index number in order to put a value from array. I wrote the following function that isn't working
#include"udf.h"
DEFINE_PROFILE(unsteady_velocity, thread, position) { real x[ND_ND]; /* this will hold the position vector */ real y;real A[251]={8,7,6,5,4,3,2,1}; real t = CURRENT_TIME; face_t f; begin_f_loop(f, thread) { F_CENTROID(x,f,thread); c0 = F_C0(f,thread); y = x[1]*2000; F_PROFILE(f, thread, position) =A[c0];} end_f_loop(f, thread)}
for example the first y , index=1 so u=A[1]=8;
thanks for the help
hillat is offline   Reply With Quote
Old   May 21, 2013, 02:13
blackmask will become famous soon enough
Are you sure that the range of c0 is in [0, 250] and at least one of these values are in [0,7] ? By the way, c language is zero-based so that A[0] = 8 and A[1] = 7.
blackmask is offline   Reply With Quote
Old   May 21, 2013, 16:23
Default yes
hilla tor
at my grid the velocity inlet border is the line x=0, -0.01<y<0.01 and I have 251 points on the line
Old   May 21, 2013, 21:46
Try this:
#include"udf.h" DEFINE_PROFILE(unsteady_velocity, thread, position) {
real x[ND_ND];
face_t f;
int ind;
y = 250*(x[1]*50+0.5);
ind = (int) (y+0.5);
F_PROFILE(f, thread, position) =A[ind];
Old   May 21, 2013, 23:51
Default ...
hilla tor
my problem is that my grid is note uniform, there is a why to know the index from the grid?
thanks for the help
Old   May 22, 2013, 00:28
It is easy to hard-coded your udf file. Print the value of c0. If the value of c0 is contiguous then shift the value so that c0 is in the range [0,250]. Or
#include
real x[ND_ND];
face_t f;
int ind=0;
F_PROFILE(f, thread, position) =A[ind++];
if the values of array A is assigned according to its appearance in the thread loop.
Old   May 23, 2013, 13:10
Default when i wrote the code
hilla tor
it was written to me the following message will running :
Divergence detected in AMG solver: x-momentum
thanks for the help
UDF problems - velocity profile Oli Fluent UDF and Scheme Programming 6 October 24, 2016 11:38
Velocity profile UDF egge24 Fluent UDF and Scheme Programming 2 May 10, 2012 14:03
Logarithmic velocity profile cfdworker Fluent UDF and Scheme Programming 0 April 23, 2009 20:09
How to specify the Velocity profile (eqn) by UDF Anant FLUENT 1 February 27, 2008 15:54
Multi step transient UDF velocity profile problem William177 FLUENT 1 February 3, 2008 07:47
