Temperature-dependent source term udf
Old   May 12, 2013, 10:42
Default Temperature-dependent source term udf
ashkan
ashkan_1984 is on a distinguished road
Dear all
I have one problem in fluent udf.I want to write one temperature-dependent source term.I want my temperature increase up to 350K because of source term,and when it reach to 350K ,source term is stop and because of free convection the temperature come back to initial values and again this cycle continue.I write one udf but I have really problem in this,please help me.
I sent the my UDF,
#include "udf.h"
DEFINE_SOURCE(cell_source, cell, thread)
real source;
real temp = C_T(cell, thread);
if(temp <350.15)
source=20000000*(1+.02*(temp-250.15));
if(temp>=350.15)
while(temp>=250.15)
source=0;
return source;
ashkan_1984 is offline   Reply With Quote
Old   May 12, 2013, 21:34
blackmask will become famous soon enough
You should have a clear definition of the point when the source terms should be switch on, and you should tell us whether such switch is global or cell-wise.
Originally Posted by ashkan_1984 View Post
Dear all
I sent the my UDF,
#include "udf.h"
real source;
if(temp <350.15)
if(temp>=350.15)
/* this branch results in an indefinite loop */
while(temp>=250.15) /*always true because temp >= 350.15*/
/* it does not change the value of temp */
source=0;
return source;
blackmask is offline   Reply With Quote
Old   May 13, 2013, 07:04
Default reply
ashkan
Thanks for your answer,
The temperature of the center of channel is important for me where the cordinate axis is (0,0,0).
I have problem in second loop,when source==0,because of free convection the cell is cooled and temperature is decrease.I want when temperature reach to initial value again repeat the cycle.
Old   May 13, 2013, 21:28
The reference cell is fixed so that you could find cell index cell_at_0 and cell thread thread_at_0 once for all. Replace the "???" by the values you find for that particular value. The value of T_lower should be a bit higher than the initial and surrounding values, or the source may never be turned on again.
#include "udf.h"
#define T_upper 350.15
#define T_lower 250.15
Thread *thread_at_0;
cell_t cell_at_0;
DEFINE_ON_DEMAND(once_for_all) {
/*The solution is provided by William Wangard*/
CX_Cell_Id *cc;
real p0[]={0.0, 0.0, 0.0};
CX_Start_ND_Point_Search();
cc = CX_Find_Cell_With_Point(p0);
if ( NNULLP(cc) ) {
thread_at_0 = cc->ct.t;
cell_at_0 = cc->ct.c;
} else {
Error("Point not in domain\n");
CX_End_ND_Point_Search();
static int SRC_ON=1;
real source;
real temp = C_T(cell_at_0, thread_at_0);
if(temp>=T_higher)
SRC_ON = 0;
if (temp < T_lower)
SRC_ON = 1;
if(SRC_ON)
} else {
source = 0.
return source;
Old   May 14, 2013, 09:24
Default reply
ashkan
I used your udf code but I have some problem that I said in following:
1-I give cell_at_0 and thread_at_0 the center of my channel cordinate [0,0,0] but the system get a error.
2-the fluent give error to static int SRC_ON=1 and I change it to int SRC_ON=1
3-the fluent give error to real temp = C_T(cell0, thread0); and I change it to
4-after this changes,I run the fluent but unfortunately my temperature isn,t increase.
I sent the last udf I used
#define cell_at_0 [0,0,0]
#define thread_at_0 [0,0,0]
#define T_upper 353.15
#define T_lower 280.15
#include "udf.h"
int SRC_ON=1;
real source;
if (temp>=T_upper)
SRC_ON=0.0;
if(temp<=T_lower)
SRC_ON=1.0;
if(SRC_ON)
source=20000000*(1+.02*(temp-250.15));}
else
source=0.0;
return source;
Old   May 14, 2013, 22:44
I have modified my code in my last post but have never test it. I will give you some suggestion but I really do not have the time for the entire solution.
Old   May 15, 2013, 06:05
Default reply
ashkan
Thank you dear,
in fact this is my M.S. thesis and I try to in for a long time.I am really confused.
Old   May 15, 2013, 07:50
Message me if you need help. The code I posted above should work for some versions of fluent. It seems that FLUENT has modified the interface for some functions among different versions.
Old   May 15, 2013, 15:57
Default reply
ashkan
I have this error in fluent 6.3 for this sentence
CX_Find_Cell_With_Point: argument 1 type mismatch (float instead of pointer to float)
and in fluent 14 for this sentence
I have this error:
CX_Start_ND_Point_Search: undeclared variable
Old   May 15, 2013, 20:41
Sorry. The line
real p0={0.0, 0.0, 0.0};
should be changed to
real p0[] = {0.0, 0.0, 0.0};
Old   May 16, 2013, 05:38
Default reply
  #11
ashkan
Sorry for my more question,I'm really beginner in udf. Now I have this error for this line
fluent write;
structure reference not implemented
I remove the _ and write this line like this thread_at_0 = cc>ct.t;
but again fluent said
ct: undeclared variable
Old   May 16, 2013, 06:03
Did you interpret the UDF? Try compile it.
Old   May 16, 2013, 12:03
Default reply
  #13
ashkan
I try to learn how to compile the file,after that I message you again.
Thanks
UDF Source term problem natantyt FLUENT 2 May 15, 2018 22:40
[swak4Foam] swak4Foam-groovyBC build problem zxj160 OpenFOAM Community Contributions 18 July 30, 2013 14:14
UDF Source Term Christian FLUENT 4 August 1, 2009 06:53
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
UDF for energy source mauricio sanchez FLUENT 0 August 30, 2005 16:56
