Use UDF to change the attack angle of flow over 3D wing
Old   May 3, 2013, 04:07
Default Use UDF to change the attack angle of flow over 3D wing
nvtrieu is on a distinguished road
Hi everyone,
I am a new with ANSYS FLUENT. I am doing simulation with the flow over 3Dwing (NACA0012). I want to change the attack angle by using UDF. Could anyone teach me how to use the UDF for this case?
thanks you!
Xavier
nvtrieu is offline   Reply With Quote
Old   May 3, 2013, 04:34
blackmask will become famous soon enough
Are you studying the pitching motion of the wing or you simply want to study the flow at several angles of attack?
blackmask is offline   Reply With Quote
Old   May 3, 2013, 06:55
Ananthakrishnan.A.S
Ananthakrishnan is on a distinguished road
Send a message via Skype™ to Ananthakrishnan
if it just the angle of attack which you want to change, you can do it directly by changing the x and y component of velocity in the velocity inlent boundary condition.
If you want to learn to do it in udf you have to do the same by writing this component inside a small c program..
this is an example of how the inlet velocity is changed according to the y distance to get a profile
http://combust.hit.edu.cn:8080/fluen...udf/node61.htm
Ananthakrishnan is offline   Reply With Quote
Old   May 3, 2013, 15:42
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
You can also do it in workbench
Far is offline   Reply With Quote
Old   May 15, 2013, 02:07
Hi everyone,
Thanks to all of you!
@blackmask: I am not going to simulate for pitching motion, only do simulation for some AoA.
@Ananthakrishnan:
Because the wing is located in the virtual wind tunnel, is it ok when I change the AoA by change the Vx, Vy components?
Old   May 15, 2013, 06:22
Ananthakrishnan.A.S
No, its not going to pose any serious threat..There will be some difference in magnitude of result between the two. But you will not be misguided..In brief, if there is a increase in lift then there will always be an increase whether you change the components of velocity or if you change the wing AOA. If you want a very very very precise result, later you can continue by changing the AOA. I suggest you to get an idea of whats happening by changing the components and then "if required" change the AOA
Old   May 16, 2013, 00:12
Thanks Ananthakrishnan,
As I understand, for this case of fluid domain, the inlet bc is a straight line. This is different compare with the semi-circle (C-shape) as many people used. So I think that for every AoA we should change the geometry rather than change the velocity components. Because the top and the bottom are wall, they are not velocity inlet.
Old   June 14, 2013, 04:37
Bikalpa Bomjan Gurung
bikalpa10 is on a distinguished road
sir Ananthakrishnan
i am doing a similar type of simulation
but whet i set inlet velocity at certain angle of attack
i get the flow accumulated at upper surface of wind tunnel
giving uneven flow throughout the wind tunnel ( higher velocity at upper surface of wind tunnel and lower velocity at lower surface of wind tunnel)
and i have chosen boundary conditions as symmetry for both upper and lower surface of wind tunnel
bikalpa10 is offline   Reply With Quote
Old   June 26, 2016, 06:53
Default angle of attack in fluent
yasegharib is on a distinguished road
hi.i want to give angle of attack in fluent but i can not.please help me
yasegharib is offline   Reply With Quote
[OpenFOAM] Plot Angle of Attack Next to Transient Pitching Airfoil dancfd ParaView 6 October 24, 2013 01:37
[CFX,ICEM] Simulation of wing / airfoil profile - pyramid elements, angle of attack Jonas_mm ANSYS 2 November 4, 2011 04:26
Grid types and change of angle of attack cpinz Main CFD Forum 6 October 10, 2011 12:56
Simulation of a complex wing in solidworks flow simulation niels1900 FloEFD, FloWorks & FloTHERM 6 April 20, 2011 11:44
modelling inviscid 2D flow at high angle of attack Ferdinando FLUENT 2 October 30, 2007 18:26
