UDF: Pointing Cell Pressure
Old   May 2, 2013, 10:26
Default UDF: Pointing Cell Pressure
Stephan Langenberg
Jim87 is on a distinguished road
While writing an UDf for compressible Polymers, I'm blocked by this Error:
line 43: Pres: undeclared variable
The manual informs that the pointer for Cell Pressure should be:
C_P(c,t) cell_t c, Thread *t pressure
I'm not able to find the mistake. Maybe someone with more experience could look at this few lines.
#include "udf.h"
DEFINE_PROPERTY(UDF_Cell_Density_Durethan,c,t)
Standard UDF Befehle
/*Domain * d;
Thread * t;
cell_t c; oder face_t f;
Node *v;*/
Aktuelle Temperatur an jeder Zelle aufrufen
temp = C_T(c,t);
Aktuellen Druck an jeder Zelle aufrufen
Pres = C_P(c,t); // This is the definition of Cell-Pressure
Definition der Variablen // Parameters
double P1 = 19598.341796875
double P2 = 22733.578125
double P3 = 2.76653862
double P4 = 5604.6762695
double P5 = 5.1758676
double P6 = 0.06848801
double P7 = 0.0017973196
spez. Volumen in Abhaengigkeit von Druck und Temperatur nach Schmidt
// Equation
Rho = 1/SpezVolu;
spezVolu = p1 / (p2 + Pres) + (p3 * temp) / (p4 + Pres) + p5 * pow (( 2.718281828, (p6 * temp + p7 * Pres));
Ende der Define Property
Any hint would be much appreciated.
Jim87 is offline   Reply With Quote
Old   May 2, 2013, 11:42
blackmask will become famous soon enough
You need to declare a variable before you can use it.
Add a line to declare Pres in the begining of your UDF function, i.e.,
real Pres;
real temp;
You should also receive another error for the variable temp because it has not been declared, either.
blackmask is offline   Reply With Quote
Old   May 2, 2013, 15:54
Stephan Langenberg
Hallo blackmask,
I corrected the mistake, but the error is the same.
It seems Irrelevant if I use double or real, the definition * = 0.0 or change the structure of the udf by placing the definition of temperature and pressure in front of the pointer.
#include "udf.h"
/*Domain * d;
Thread * t;
Node *v;*/
temp = C_T(c,t);
pressure = C_P(c,t);
double pressure = 0.0;
double temp = 0.0;
double P1 = 19598.341796875;
double P2 = 22733.578125;
double P3 = 2.76653862;
double P4 = 5604.6762695;
double P5 = 5.1758676;
double P6 = 0.06848801;
double P7 = 0.0017973196;
Rho = 1/SpezVolu;
spezVolu = p1 / (p2 + pressure) + (p3 * temp) / (p4 + pressure) + p5 * pow (( 2.718281828, (p6 * temp + p7 * pressure));
Old   May 2, 2013, 23:35
Try this one. The comments are deleted for neatness. There is a reason that I put the two lines immediately after the open curly bracket ({) in my last post. You need to declare the variable first before use. You should use 'real' instead of 'double'. The 'real' is an alias for 'float' in single precision solver and 'double' in double precision solver.
#include "udf.h"
double temp = 0.0;
double spezVolu;
temp = C_T(c,t);
Rho = 1/SpezVolu;
Old   October 20, 2013, 14:56
Harshad
harsh_999 is on a distinguished road
pressure and temp are calculated by C_P(c,t) and C_T(c,t) respectively
I think,we cant assign value 0.0
Simply this should work:
real pressure, temp;
Inform me whether u cud succeed....
Gud luck
harsh_999 is offline   Reply With Quote
Pressure modification using flux at outlet boundary (udf) UnclePetors Fluent UDF and Scheme Programming 1 January 1, 2013 10:47
Pulsatile pressure inlet with pressure outlet a.lynchy FLUENT 3 March 23, 2012 14:45
Does star cd takes reference pressure? monica Siemens 1 April 19, 2007 12:26
UDF to control Static Pressure (in cylinder) James FLUENT 0 July 20, 2004 08:54
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) HB &DS CFX 0 January 9, 2000 14:19
