How to define the turbulent k near the wall ? |
April 30, 2013, 03:27 |
hp
Rep Power: 15 |
hello everyone,
I wish to define the solution of the turbulent kinematic energy solution near the wall, in Fluent. My case is standard k-e with standard wall function. From the ansys help we can see that the k-equation is solved in the whole domain including near the wall, while the epsilon adjacent to the wall is calculated from the near-wall equ with is derived from the local equilibrium hypothesis. After the solution I found that the production of k (Gk) is zero everywhere on the wall, which is very different from the Gk equ based on the local equilibrium hypothesis. I wish to give a definition of the k in order to force the local equilibrium near the wall. Could anybody give some advice how i can do this? Many thanks!! |
May 13, 2013, 23:54 |
#3 | |
hp
Rep Power: 15 |
I saw in many literatures they specified the value of k on the wall, which is, to give a Diriclet boundary for the equation. For example, some can specify the k as u*^2/sqrt(Cmu), which is, to force the local equilibrium on the wall. Or some can give a zero k on the wall. I checked the results of the Fluent on an external flow around a cylinder with k-e and standard wall function. When I compared the computed k to the "u*^2/sqrt(Cmu)" , I saw in the wake region the computed value differed a lot. I wonder whether this would be a key point to cause the differences between my results and those in the literatures. So I wish to specify the k on the wall, in the Fluent, eg. though a UDF~~ Could anybody shed some light~~ turb k.jpg |
Turbulent cyclic pipe flow, wall functions and y+ | clyde | OpenFOAM Running, Solving & CFD | 3 | March 17, 2014 07:08 |
what is the 'Wall Turbulent Prandtl Number'? | begginer | FLUENT | 2 | October 1, 2013 23:42 |
Water subcooled boiling | Attesz | CFX | 7 | January 5, 2013 04:32 |
[ICEM] Export ICEM mesh to Gambit / Fluent | romekr | ANSYS Meshing & Geometry | 1 | November 26, 2011 13:11 |
Define wall using UDF | Abhijit | FLUENT | 3 | October 26, 2007 11:16 |
