DEFINE_PR_RATE UDF is not called with the coupled solution option?
Old   April 24, 2013, 05:44
Default DEFINE_PR_RATE UDF is not called with the coupled solution option?
guan
guanql88 is on a distinguished road
hi,
I am confused about the particle reaction rate UDF “DEFINE_PR_RATE
". In the fluent udf manul it says: "Note that a DEFINE_PR_RATE UDF is not called with the coupled solution option, so you will need to disable the Coupled Heat Mass Solution option in the Discrete Phase Model panel when using it"
but if the fluid and particle simulations were not coupled, how can I get the correct results?
guanql88 is offline   Reply With Quote
Old   April 25, 2013, 07:03
Paritosh Vasava
vasava will become famous soon enough
I think here coupling has something to do with the coupling of the differential equations and not the coupling of the solvers.
vasava is offline   Reply With Quote
Old   April 25, 2013, 09:09
guan
Thank you, I have found this in Fluent help: By default, the solution of the particle heat and mass equations are solved in a segregated manner. If you enable the Coupled Heat-Mass Solution option, FLUENT will solve this pair of equations using a stiff, coupled ODE solver with error tolerance control. The increased accuracy, however, comes at the expense of increased computational expense.
CFL Condition Matt Umbel Main CFD Forum 19 June 30, 2020 09:20
solution not converging with UDF. Please help!! shunahshep FLUENT 2 March 8, 2005 19:45
CFX-ANSYS coupled solution Wenca CFX 3 December 23, 2004 22:51
Accessing solution data in UDF Ale FLUENT 1 June 12, 2002 01:25
Wall functions Abhijit Tilak Main CFD Forum 6 February 5, 1999 02:16
