Compiling UDFs in Ansys Fluent 13.0 on openSuse 12.3 computer
Old   April 23, 2013, 11:48
Default Compiling UDFs in Ansys Fluent 13.0 on openSuse 12.3 computer
triebl is on a distinguished road
I'm trying to compile UDFs in Ansys Fluent 13.0 on my Linux openSuse 12.3 computer.
I installed gcc as a compiler but when I want to build a library, an error occurs:
sh: line 1: make: command not found
Does anybody have an idea how i can solve this problem?
Kind regards
Chris
triebl is offline   Reply With Quote
Old   April 23, 2013, 22:26
blackmask will become famous soon enough
you need to install the make package using the following command with root privilege.
#zypper in make
blackmask is offline   Reply With Quote
Old   April 24, 2013, 05:59
Thank you, it works!
udf fluent compiler linux
prePDF preprocessor in FLUENT (ANSYS 12 version) anee Fluent UDF and Scheme Programming 7 March 18, 2013 23:57
few quesions on ANSYS ICEMCFD and FLUENT Prakash.Paudel ANSYS 0 August 12, 2010 13:07
export data from fluent to ansys galapago FLUENT 0 August 4, 2010 15:04
Compiling UDF in Fluent 12 jsm FLUENT 1 July 22, 2009 08:40
Fluent does not work on openSUSE 11.0 Stanislav Sviderek FLUENT 1 July 28, 2008 18:21
