Cannot Execute on Demand
Old   April 14, 2013, 08:53
Unhappy Cannot Execute on Demand
Denis is on a distinguished road
Dear forum users,
I am new to Fluent and have the following problem:
I compile an ON_DEMAND UDF:
#include "udf.h"
DEFINE_ON_DEMAND(on_demand_calc)
Domain *d;
Thread *t;
d = Get_Domain(1);
printf("Hello World\n");
It compiles without errors, then I Load it. When I go to Define-> User-Defined -> Execute on Demand, choose "on_demand_calc::libudf", and press Execute, totally nothing happens (no any new text is coming in the Fluent console). Then when I quit Fluent, the "Hello World" text appears in the console (that many times as I have pressed the Execute button) just half a second before Fluent closes. Or sometimes the text appears when I unload the "libudf" in "Manage".
I have this issue for serial and parallel(3 cores) sessions of Fluent.
My software and system:
Ansys 14.5
Windows 8
MS Visual Studio 2010.
Can anybody please give a suggestion what is going wrong?
Thanks in advance!
Denis is offline   Reply With Quote
Old   April 15, 2013, 06:33
Max
coglione is on a distinguished road
Your code is definitely ok, maybe there is something in the GUI going on.
Try Message0("Hello World\n") instead of printf and see what happens.
cheers
coglione is offline   Reply With Quote
Old   April 19, 2013, 10:19
Thank you, the Message("Hello World\n"); worked.
Old   March 5, 2018, 05:09
Default Similar problem
Sai Guruprasad Jakkala
saiguruprasad is on a distinguished road
I am facing a similar problem while interpreting an EXECUTE_AT_END udf. I need to print values into a file at the end of each iteration, but it does not. After I close the Fluent session, it writes the values to the file in the reverse order.
#include"udf.h"
FILE *fout;
DEFINE_EXECUTE_AT_END(trial_1)
Domain *mixture_domain;
Domain *subdomain;
int phase_domain_index;
float t;
float a;
real xx,yy;
float ct;
cell_t cell;
Thread *cell_thread;
real xc[ND_ND];
mixture_domain=Get_Domain(1);
t=CURRENT_TIME;
fout=fopen("a.out","a");
xx=0;
yy=0;
ct=0;
sub_domain_loop(subdomain, mixture_domain, phase_domain_index)
fprintf(fout,"\n %f \n",t);
if (DOMAIN_ID(subdomain) == 3)
thread_loop_c(cell_thread,subdomain)
begin_c_loop_all(cell,cell_thread)
C_CENTROID(xc,cell,cell_thread);
a=C_VOF(cell,cell_thread);
xx+=a*xc[0];
yy+=+a*xc[1];
ct=ct+1;
end_c_loop_all(cell,cell_thread)
fprintf(fout,"%g %g \n",xx,yy);
The output appears like this(I have put only the start of the output file):
0.005000
0.005000
4233.25 4220.46
0.004000
0.004000
4233.21 4220.42
It decreases till zero timestep. How can I make it print in the correct order and after each timestep instead of closing the fluent session?
saiguruprasad is offline   Reply With Quote
Old   March 5, 2018, 06:56
obscureed is on a distinguished road
Hi Sai Guruprasad,
It is slightly weird that you get the output in reverse order, but the outcome of your code is highly implementation-dependent, and reliant on buffering etc. See for example https://wiki.sei.cmu.edu/confluence/...s+already+open
The current sequence is:
(1) At the first timestep, you open the file-pointer fout and write something to it. This output is saved in a buffer. The file stays open and fout retains its pointer.
(2) At the next timestep, you re-open the same file and put the new file-pointer into fout. (It is unclear, implementation-dependent, etc what happens to the old file-writing sequence that was held in fout.) Then you write something, which is saved in a new buffer.
... repeat step (2)
The output to the file is only sorted out when Fluent quits, and the buffers are cleared out.
One answer to all this is to fclose the file pointer at the end of each UDF (and to continue to fopen it at the start of each UDF).
An alternative answer is to fopen the file pointer only at the start of a group of timesteps, and then to fclose it when you want to see the output. This is slightly more efficient -- the operating system can build up a decent buffer of text, and write to file less frequently -- but the bureaucracy is possibly not worth the effort in this case. If you do go down this route, it may be helpful to initialize fout to a definite value:
FILE *fout = NULL;
So that you can always test fout to see whether a fopen call is needed. Without an initialization, this is not safe on the first visit.
You should be aware that this whole method is not ready for running Fluent in parallel.
Good luck!
Ed
obscureed is offline   Reply With Quote
Old   March 11, 2018, 02:25
Thank you obscureed.
Putting a fclose(fout); at the end of the program helped in printing the results at the end of every time step.
Old   June 26, 2018, 05:40
Default Define on demand(copy uds to udm) in fluent
sadik
sumagaji is on a distinguished road
Hello, can someone help me on how to copy uds to udm i want to copy data from uds to udm and i use the following code. But i did not copy the data.
#include "udf.h"
#include"sg.h"
DEFINE_ON_DEMAND(copy_uds_to_udm)
Domain*d=Get_Domain(1);
Thread*t;
cell_t c;
thread_loop_c(t,d)
begin_c_loop(c,t)
C_UDMI(c,t,0)=C_UDSI(c,t,0);
end_c_loop(c,t)
return;
need your help. Thanks
sumagaji is offline   Reply With Quote
execute udf after convergence wanghaojie Fluent UDF and Scheme Programming 6 April 5, 2019 03:00
execute udf in ss & transient simulation hosseinhgf FLUENT 0 December 1, 2010 09:41
error while execute on demand Anderson Main CFD Forum 4 October 17, 2008 12:48
On demand UDF error RS FLUENT 0 May 10, 2007 13:54
execute on demand pourak FLUENT 0 April 20, 2007 07:24
