April 11, 2013, 03:47 |
surface reaction UDF
tjut-wx
Rep Power: 17 |
hey!i am modelling the surface reaction,the overal reaction equation:2O3 -> 3O2. and its reaction rate formular is: r = K*b*O3/(1+b*O3); my UDF code as follows:
#include "udf.h" #define K 6.8586e-11 #define b 15296.9e3 DEFINE_SR_RATE(my_rate,f,t,r,mw,yi,rr) { Thread *t0 = t->t0; cell_t c0 = F_C0(f,t); real o3 = yi[0]; real rho_w = 1.0, T_w = 300.0; T_w = F_T(f,t); rho_w = C_R(c0,t0)*C_T(c0,t0)/T_w; o3 *=rho_w/mw[0]; *rr = K*b*o3/(1+b*o3); } the problem is:after compile and hook the UDF,the calcucation results showed that the reaction rate on the defined surface was zero。is there anyone who can help me analyse where the problem is and how to solve it? thanks! |
January 7, 2014, 15:52 |
Sebastian
Rep Power: 15 |
Good afternoon, excuse me, did you find a solution to your problem? I’m experiencing the same; I would appreciate greatly your help.
August 8, 2017, 13:06 |
Hello ! Isn't it too late????
#3 | |
sang-joon
I think that the problems may be in the definition of yi[] and mw[]. You must check the order of species in your mixture-template. |
[ICEM] Problems with coedge curves and surfaces | tommymoose | ANSYS Meshing & Geometry | 6 | December 1, 2020 12:12 |
question about udf for "particle surface reaction rate" | lili | Fluent UDF and Scheme Programming | 0 | January 9, 2013 04:37 |
udf for partical surface reaction | blaid | FLUENT | 0 | April 25, 2011 08:24 |
UDF for catalyst volumetric reaction, temperature overshoot though rate is small | elmcmaster | FLUENT | 0 | October 11, 2010 10:37 |
chemical reaction - decompostition | La S. Hyuck | CFX | 1 | May 23, 2001 01:07 |
