Volume fraction UDF in mixture model
Old   April 2, 2013, 10:23
Default Volume fraction UDF in mixture model
wawa
wawa is on a distinguished road
Hi everybody,
Can I use C_VOF(c,pt[i]) in a UDF for the Multiphase Mixture model ?
FLUENT is giving me 'ACCESS_VIOLATION' error...
Can anybody suggest an alternative to get the volume fraction of a phase in my UDF ?, or even better, the pressure of a particular phase in the mixture ?
Thanks
wawa
wawa is offline   Reply With Quote
Old   April 3, 2013, 02:47
Paritosh Vasava
vasava will become famous soon enough
Can you show your UDF please.
vasava is offline   Reply With Quote
Old   April 3, 2013, 05:58
wawa
I'm basically trying to calculate the partial pressure of water-vapour in a mixture of air, liquid water and water-vapour. I'm using the mixture model, with evaporation-condensation, and the 'DEFINE_PROPERTY' is used to obtain the saturation temperature to use in the model. I need the partial pressure of water-vapour in order to calculate the saturation temperature (via an experimental equation).
DEFINE_PROPERTY(sat_temp,c,t)
Thread *tm, **pt;
real par_pres;
real sat_temp;
tm = THREAD_SUPER_THREAD(t);
pt = THREAD_SUB_THREADS(tm);
par_pres = C_VOF(c,pt[2])*C_P(c,t);
/*pt[2] because 2nd secondary phase is water vapour*/
sat_temp = pow(par_pres,0.11);
return sat_temp;
My issue is that I cannot access the volume fraction C_VOF(c,pt[2]) in FLUENT. THe code compiles well, but at initialisation, it gives me 'ACCESS VIOLATION' error.
Can you help ?
Old   April 3, 2013, 10:08
Paritosh Vasava
I have doubt if you can use the macro C_VOF(c,pt[2]) with mixture model (Anyone?). That could be the issue. Can you test your code without 'C_VOF(c,pt[2])' and see if it works.
Old   April 3, 2013, 13:14
wawa
Yes, it does work without C_VOF...
Is there another way to get the volume or mass fraction with the mixture model ?
udf: volume fraction gradient in eulerian model jwwang FLUENT 22 April 15, 2015 07:27
volume fraction in mixture model and VOF???? multiphase-flow FLUENT 4 August 7, 2014 11:35
VOF model - volume fraction residual question Wim Heirwegh FLUENT 9 July 8, 2013 14:44
On the damBreak4phaseFine cases paean OpenFOAM Running, Solving & CFD 0 November 14, 2008 22:14
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 15:00
