UDF Compiling - can't read ..\..\src\xxx_udf.c: No such file or directory
Old   March 28, 2013, 12:22
Default UDF Compiling - can't read ..\..\src\xxx_udf.c: No such file or directory
Willy Bernal
willy is on a distinguished road
I am trying to build a UDF file, but seems to be working fine when I select it on the Dialog. The output on the screen shows the next. However, the linking process does not occur.
> Deleted old C:\user\Fluent1\libudf\src\libudf\win64\3ddp\libud f.dll
1 file(s) copied.
(system "copy "C:\PROGRA~1\ANSYSI~1\v130\fluent"\fluent13.0.0\sr c\makefile_nt.udf "C:\user\Fluent1\libudf\src\libudf\win64\3ddp\make file" ")
1 file(s) copied.
(chdir "C:\user\Fluent1\libudf\src\libudf")()
(chdir "win64\3ddp")()
# Generating udf_names.c because of makefile radiant_3_udf.obj
Done.
The Process seems to be working ok. It will generate the following folders and files:
\libudf
\src
radiant_3_udf.c
\win64
\3ddp
makefile
log
radiant_3_udf.obj
ud_io1.h
user_nt.udf
The log file has this output.
sed: can't read ..\..\src\radiant_3_udf.c: No such file or directory
NMAKE : U1077: 'sed' : return code '0x2'
Stop.
Is this a compiler issue? does not seem like it. Any ideas? I do not have administrative privileges for this. Need to make sure that that is the problem.
Thanks in Advance!
willy is offline   Reply With Quote
compiler, fluent 13, nmake, udf
GPU Linear Solvers for OpenFOAM gocarts OpenFOAM Announcements from Other Sources 37 August 17, 2022 15:22
[swak4Foam] swak4Foam-groovyBC build problem zxj160 OpenFOAM Community Contributions 18 July 30, 2013 14:14
Problem installing on Ubuntu 9.10 -> 'Cannot open : No such file or directory' mfiandor OpenFOAM Installation 2 January 25, 2010 10:50
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 02:24
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 15:00
