DEFINE_INIT parallel udf error during solution initialization |
March 23, 2013, 10:37 |
nadesan
Rep Power: 14 |
hi,
I wrote a parallel udf to initialize the x, y and z velocity, for a 3D open channel flow case, using "DEFINE_INIT". Following is my code #include "udf.h" #include "metric.h" #include "mem.h" #define ymax 0.001 DEFINE_INIT(flow_field,d) { #if !RP_HOST face_t f; Thread *tf; real x[ND_ND]; real y; /**loop over all face threads in the domain**/ thread_loop_f(tf,d) { /**loop over all faces in the face thread**/ begin_f_loop(f,tf) if PRINCIPAL_FACE_P(f,tf) { F_CENTROID(x,f,tf); y=x[1]; F_U(f,tf)=(ymax+y)*(ymax-y)*48.6/(ymax*ymax); F_V(f,tf)=0.0; F_W(f,tf)=0.0; } end_f_loop(f,tf) } #endif } The code is in tact while compiling and loading. But while i am initializing the solution i am getting an error which reads "stack backtrace generated for node id=0 (pid=17332) on signal 11" . . . . . . . . . . 999999: mpt_read:error:read failed trying to read 4 bytes: Resource temporarily unavailable. The fluent process could not be started .... Could someone please throw some light on this issue. Your help is much appreciated Thanks a lot Rgds nadesan |
May 28, 2013, 14:06 |
#2 | |
Rep Power: 16 |
Hi nadesan,
Did you solve the problem? thanks! Quote:
June 4, 2013, 22:55 |
yep.
I have this error when I was running a very simple parallel case without any UDF. the case can run successfully in serial, but failed parallel. |
"Define_Profile" UDF for parallel solver | Antoine | Fluent UDF and Scheme Programming | 9 | February 29, 2016 07:09 |
Parallel INIT UDF trouble | mil3st3g | Fluent UDF and Scheme Programming | 2 | January 6, 2011 15:07 |
Parallel Fluent +UDF | Jack Martinez | FLUENT | 0 | June 28, 2007 12:19 |
Parallel UDF Error | Andrew | FLUENT | 2 | March 30, 2007 12:11 |
UDF in Parallel | Gavin | FLUENT | 1 | June 19, 2005 23:17 |
