Help: CURRENT_TIMESTEP with FLUENT Steady Solver
Old   March 11, 2013, 11:37
Default Help: CURRENT_TIMESTEP with FLUENT Steady Solver
Li Huang
lihuang is on a distinguished road
Dear all,
I am trying to model partitioning of organic compounds between gas and granular phases. I use DEFINE_SOURCE macro to pass mass transfer rate back to steady solver. As I understand that time dependent terms are not included in the equations solved by fluent steady solver. But when it comes to calculating mass transfer in DEFINE_SOURCE macro, I have delta_t involved. And CURRENT_TIMESTEP macro does return a constant value of 1, which seems a fake time step. It seems to me now that the mass transfer rate defined in DEFINE_SOURCE should not involve delta_t. Please correct me if i am wrong.
Thanks.
lihuang is offline   Reply With Quote
Old   March 13, 2013, 02:57
SSL
msaeedsadeghi is on a distinguished road
You're right.
msaeedsadeghi is offline   Reply With Quote
Old   March 14, 2013, 10:25
Li Huang
Originally Posted by msaeedsadeghi View Post
You're right.
Hi Saeed,
Thanks so much for your clarification.
For Fluent Steady Coupled solver, there is a Courant number, which can be set to change local time step for solving continuity and momentum equations according to fluent 6.x user's guide. The default value for steady coupled implicit Courant number has been changed from 5 (fluent 6.x) to 200 (fluent 12.1). And in fluent 12.1, Courant number for pressure-based coupled solver of value lower than 10 is NOT recommended by the guide. So I am wondering if there are some sort of changes have been made.
Could anyone please comment on this?
Thank you all!
Li
Fluent IcePak - AMG Solver Russ FLUENT 2 December 31, 2018 10:57
Compressible flow solver in Fluent jwillie2000 FLUENT 4 May 25, 2012 10:58
convergence issues on steady state solver icemaniac178 CFX 1 March 30, 2011 20:11
IS FLUENT A VISCOUS SOLVER?? karthik FLUENT 4 August 1, 2005 13:49
compressible two phase flow in CFX4.4 youngan CFX 0 July 2, 2003 00:32
