UDF for calculating Oscillatory Shear Index (OSI) |
#21 |
shima mohammadi
Rep Power: 3 ![]() |
#22 | |
shima mohammadi
i compiled udf of osi and the fluent project was completed successfully! but I don't know exactly in what time range the osi is calculated?! First, I run three cycles and then I save the results of the fourth cycle. thank you! |
#23 |
Alexander
Rep Power: 34 ![]() ![]() |
show udf you are using
best regards ****************************** press LIKE if this message was helpful |
#25 |
fgs gs
Rep Power: 0 ![]() |
Your question"i compiled udf of osi and the fluent project was completed successfully!but I don't know exactly in what time range the osi is calculated?!
First, I run three cycles and then I save the results of the fourth cycle" I hvae the same problem, if you solved this question, can you give some suggestions? |
specified shear at wall - temperature gradient - UDF - access violation error | senD | Fluent UDF and Scheme Programming | 9 | September 18, 2014 07:29 |
Accessing wall shear stress using UDF | Robert | Fluent UDF and Scheme Programming | 2 | July 31, 2013 08:34 |
UDF of shear flows - Just need a little little help | yannossss | FLUENT | 5 | July 11, 2011 07:11 |
OpenFOAM install on Ubuntu Natty 11.04 | bkubicek | OpenFOAM | 13 | May 26, 2011 05:48 |
UDF for wall slipping | HFLUENT | Fluent UDF and Scheme Programming | 0 | April 27, 2011 12:03 |
