November 20, 2014, 12:19 |
#41 | |
Rep Power: 16 |
I am using damping function, not wall function ,but I think You should save it in face memory....
November 20, 2014, 12:40 |
#42 |
Ali.E
Rep Power: 16 |
I do not use wall function, too. But, you need to calculate shear stress on the wall boundary.
Here, you can find my UDF and my Fluent case/data files. May I ask you to glimpse them, https://www.dropbox.com/sh/rg87mkr95...MyjuKLP-a?dl=0 It would be appreciated if you let me know about your idea. |
November 20, 2014, 13:39 |
#43 | |
Rep Power: 16 |
you said that you running the code but you did not compile it at all and the code is not hooked as well how do you know that code is not working?
are you a student? Quote:
November 20, 2014, 15:03 |
#44 |
Ali.E
Rep Power: 16 |
Actually, I just sent the case/data files and UDF code without compiling. In this case/data file, I did not compile the UDF, this is my solution without adding UDF. I just sent this case/data files to see the SST results obtained by Fluent. If you compile the UDF and start runnig, you'll find different answer.
For compiling, I have done these steps: 1-go to define/user-defined/functions/compile and add the UDF and then bottom "Build" and "Load" 2-go to define/user-defined/scalars and put 2 UDS 3-go to model/viscous and hook Turbulent viscosity 4-go to "Fluid" and click on "Source terms" and hook two source terms for two UDS 4-go to Boundary conditions and select "plate" as wall and then select "fixed value" for both UDS, put zero for UDS1 (as turbulent kinitic energy) and select wall UDF for UDS2 (as specific dissipation rate) 5-go to pressure outlet boundary condition and click on "UDS" tap, then put the value of UDS1 and 2. I do the same procedure for velocity inlet boundary, too 6-go to solution control/equations, and select User Scalar 0" and "User Scalar 1". Moreover, I uncheck "Turbulence" 7-start calculation These are the whole works that I have done. I am student and really need to write an UDF for SST model and valid it with Fluent results. Please help me, |
December 2, 2014, 09:02 |
#45 |
Ali.E
Rep Power: 16 |
Hello my friend,
what do you think about my steps for running UDF? Are those steps correct? May I know your comment? |
December 2, 2014, 11:58 |
#46 |
Rep Power: 16 |
everything is correct…If your code is correct then maybe the BC or mesh is wrong…I am not familiar with k-omega SST but you should check BC and mesh
What is the mesh size, you are using near the plate? |
December 2, 2014, 12:37 |
#47 |
Ali.E
Rep Power: 16 |
Y+ is less than 1 and I use velocity inlet, pressure outlet and wall as boundary condition
December 2, 2014, 14:08 |
#48 |
Rep Power: 16 |
did you try y+ 10?
are u using first order or second order scheme ? what is the relaxation factors for UDSI terms? |
December 2, 2014, 14:14 |
#49 |
Ali.E
Rep Power: 16 |
December 2, 2014, 14:54 |
#50 |
Rep Power: 16 |
December 2, 2014, 15:57 |
#51 |
Ali.E
Rep Power: 16 |
In wall boundary condition, I fix k=0 and Omgea is obtained as bellow:
/*==============Wall boundary=======================*/ DEFINE_PROFILE(wall_d_bc,t,i) { Thread *t0; face_t f; cell_t c, c0; double F_x,area,A[ND_ND],yplus,wshear; begin_f_loop(f,t) { c0 = F_C0(f,t); t0 = THREAD_T0(t); yplus = C_STORAGE_R(f,t,SV_WALL_YPLUS_UTAU); /* Y+*/ F_x = F_STORAGE_R_N3V(f,t,SV_WALL_SHEAR)[0]; F_AREA(A, f, t); area = NV_MAG(A); wshear=-1*F_x/area; F_PROFILE(f,t,i) = 6.*wshear/(0.075*C_MU_L(c0,t0)*SQR(yplus)); } To put them, I go to Define/boundary condition/wall and then select "edit". A new window for the plate will be opened. I select UDS tab and then put fixed value of k=0 and a fixed value of Omega according to the "wall_d_bc" UDF I put a fixed value of k and omega at inner and outer boundary conditions. Anyway, I have a question about the initialization, as you see in my UDF, I have not initialized any UDS. How do you initialize them in your code? Did you add the turbulence contributions to momentum equation as sources? Last edited by behest; December 4, 2014 at 08:12. |
December 6, 2014, 21:14 |
hi
#52 |
Qureshi M Z I
Rep Power: 13 |
i want ot modify the Production term of k. i have UDF but i don't know how can i add my UDF. please help me .
thanks |
December 7, 2014, 08:20 |
#53 |
Ali.E
Rep Power: 16 |
If you would like to modify production term of k, you may need an UDF for the turbulence model. It is not possible to write an UDF and change production trem. Fluent does not allow us to access this term.
December 7, 2014, 19:08 |
hi
#54 |
Qureshi M Z I
Rep Power: 13 |
hi behest, thanks for the answer, you mean i need full turbulence model UDF instead of one term UDF just for production term of k.
regards, |
October 26, 2016, 21:09 |
#55 | |
ali
Rep Power: 18 |
I am struggling with implementing a new intermittency transport equation that I have derived in fluent and you seem to be a very knowledgable person in this regard. I understand that I have to use UDS. But I am not sure how I should change the value of intermittency inside the UDF? I am guessing that I have to use DEFINE_ADJUST for that reason but then again I do not know how to access (read) the value of intermittency from the solver. Also two other problems: 1) For adding source terms to intermittency can I simply add it through the sources tab in the fluids window or it has to be done through UDF as well. 2) Diffusion term: This is the part that I literally do not have any clue about. Any help is much appreciated. Sorry if my problems sound childish to you. I have been using CFX for quite a while and I know how to work with that but I am quite a newbe in fluent. I would really really appreciate it if you can help me with that. I am lost and do not have much time. As a thank you I will gladly promote your publications in CFD field in my upcoming papers. Thanks a lot, Ali |
October 27, 2016, 18:25 |
#56 | |
ali
Rep Power: 18 |
It has been more than 3 years since the last time you updated this post. Just wanted to know if you were successful in solving your problems? I want to replace the transport equation for intermittency with some other transport equation that we have derived. The problem is I can not find the Macro name for intermittency and do not know how to bypass the default transport equation for intermittency in FLUENT (Langtry-Menter transport equations) P.S. I want to continue using transitional SST turbulence model and just have fluent use my transport eq. instead if its own |
An error has occurred in cfx5solve: | volo87 | CFX | 5 | June 14, 2013 18:44 |
how to define the symmetric boundary condition for Menter's SST turbulence model? | flyingseed | Main CFD Forum | 8 | November 24, 2012 03:53 |
What model of turbulence choose to study an external aerodynamics case | raffale | OpenFOAM | 0 | August 23, 2012 06:45 |
Reynolds Stress Model in Fluent Vs CFX | Tim | FLUENT | 0 | December 6, 2005 23:03 |
Sinclair Model + secondary turbulence | Yi | FLUENT | 0 | October 26, 2001 14:37 |
