Compiling UDF within Workbench
Old   February 19, 2013, 21:44
Question Compiling UDF within Workbench
NPat is on a distinguished road
Dear friends,
I'm able to compile a UDF from FLUENT launcher, but it cannot be done when I start FLUENT from Workbench. Anyone has some tip on how to do that?
Regards,
Natan
NPat is offline   Reply With Quote
Old   March 13, 2013, 07:25
Paritosh Vasava
vasava will become famous soon enough
Are you sure that your UDF is in same place at your case files.
Put your UDF in CaseFolder>dp0>FFF>Fluent and then try to compile.
vasava is offline   Reply With Quote
Old   April 15, 2013, 13:42
michujo is on a distinguished road
Hi, I am facing the exact same problem.
I was able to compile the UDF and run the case launching Fluent without Workbench, but It is not working within Workbench.
Did you managed to solve the problem? If yes, could you please explain how you did it?
Many thanks in advance.
Regards,
Michujo.
EDIT: Yes, the UDF source files are in the right folder. It worked fine with Fluent (outside Workbench).
michujo is offline   Reply With Quote
Old   April 24, 2013, 04:36
Paritosh Vasava
Do compiling and interpreting both work outside workbench? If the compiling is not working then you must correct the visual basic set-up for fluent.
Old   December 11, 2014, 09:55
G. S.
gerardosrez is on a distinguished road
Where you able to solve your issue with workbench?? I have the same question because you have to start workbench from SDK so what would be the working directory??? the one with the workbench files or the one with the fluent flies (udf lib etc)
Best regards...
gerardosrez is offline   Reply With Quote
Old   December 17, 2014, 14:45
hosein
ho3ein.agl is on a distinguished road
good news
step1: uninstall visual studio express 2013 or 2010 or c++
step2: install Microsoft Visual Studio 2010 Ultimate v10.0 (or pro)
everything is fine
even dont need to start workbench or fluent from SDK
ho3ein.agl is offline   Reply With Quote
compilation, fluent, udf, workbench
compiling udf at window Nt(64BIT) noa FLUENT 3 July 30, 2014 00:01
ERROR in compiling UDF stefanos Fluent UDF and Scheme Programming 1 April 25, 2012 08:37
UDF compiling problem in Flient 6.3 jeevan kumar FLUENT 2 February 25, 2009 01:43
udf compiling problem akr FLUENT 3 August 22, 2007 08:14
On Compiling a UDF David Chabot FLUENT 5 May 20, 2005 10:13
