January 2, 2016, 01:31 |
#61 |
Bahamin
Rep Power: 10 |
Dear All,
I need UDF representing a logarithmic variation for temperature as boundary condition in one wall of my geometry. I appreciate you advice me. (2D problem) The temperature varies logarithmically from x=0,y=225mm from 75 (centigrade) to x=1000 mm,y=225 to 21(centigrade). there is no z direction. I appreciate if you guide me. Last edited by Roil; January 2, 2016 at 17:55. |
January 2, 2016, 17:35 |
#62 |
Rep Power: 18 |
Use the DEFINE_PROFILE macro (see the UDF manual). Write out the temperature equation as a function of x as you'll need to code this function into the UDF. The first example in the UDF manual applies a parabolic pressure profile which should give you a starting point for your code.
January 3, 2016, 04:13 |
#63 |
Astio Lamar
Rep Power: 14 |
Hi!
It is easy as it said by others. just find an equation representing your temperature variation in Kelvin and add it to the below UDF. That's it! #include "udf.h" DEFINE_PROFILE(inlet_x_temperature, thread, position) { real x[ND_ND]; /* this will hold the position vector */ real y; face_t f; begin_f_loop(f, thread) { F_CENTROID(x,f,thread); y = x[1]; F_PROFILE(f, thread, position) = Your Equarion; } end_f_loop(f, thread) } |
August 5, 2016, 20:09 |
UDF for temperature variation with time and space
#64 |
mm
Rep Power: 9 |
Respected members
I have to write a UDF for temperature variation along with time and flow domain. actually temperature is varying with time at four points in flow domain, (different relation for time and temperature at these points. for example at x=0.20m i have following code: DEFINE_PROFILE(solid_temperature,thread,position ) { face_t f; begin_f_loop(f,thread) { real t = RP_Get_Real("flow-time"); if ( t <= 100.0 ) { F_PROFILE(f,thread,position) = 379.48 + 0.0004*t; } else if (100.0 < t && t <= 180.0 ) { F_PROFILE(f,thread,position) = -8.34641*pow(10,-6)*pow(t,4.0)+ 5.49800*pow(10,-3)*pow(t,3.0)- 1.35243*pow(t,2.0)+ 1.47648*pow(10,2.0)*t - 5.51650*pow(10,3.0); } else { F_PROFILE(f,thread,position) = 727.82; } } end_f_loop(f,thread) } at x=0.40m (second point) i have following relations: if ( t <= 100.0 ) { F_PROFILE(f,thread,position) = 379.48 + 0.0004*t; } else if (100.0 < t && t <= 180.0 ) { F_PROFILE(f,thread,position) = 0.2716*t + 494.4; } else { F_PROFILE(f,thread,position) = 727.82; } } end_f_loop(f,thread) } and similarly for other 2 points can any body pl guide me how to include these points in code. i just know how to write variation of temperature with time but i could not find way to write above relations at different points. Please guide me. thanks. |
May 21, 2018, 08:34 |
#65 |
erfan
Rep Power: 8 |
hi i have same problem!!!can you please help me?
suppose i have a cylinder shaped cpu and i want a temperature profile on it which is varying with radius and angle! for example i want this profile: T=25*r+2sin(teta) teta is from zero to 360 on top of the cylinder. |
August 5, 2018, 04:32 |
#66 | |
Rep Power: 8 |
I have written a udf for this but it is showing "segmentation fault". can you tell me where might be the problem ? Code:
#include "udf.h" DEFINE_PROFILE(fluxloss,thread,position) { real h; real T_ext; face_t f; begin_f_loop(f,thread) { h = 10; T_ext = 300; F_PROFILE(f,thread,position) =-10*(WALL_TEMP_INNER(f,thread)-T_ext); } end_f_loop(f,thread) } |
August 7, 2018, 03:41 |
#67 |
Rep Power: 26 |
The problem is WALL_TEMP_INNER.
We don't know what this is. It is not something standard in Fluent, so it is something that you added. Did you define this somewhere else in your code? If no: you are putting words that have no meaning in your code, and Fluent does not know what to do with this, so it gives an error. If yes: tell us how you defined it! |
August 7, 2018, 12:41 |
#68 | |
Rep Power: 8 |
http://cape-forum.com/index.php/topic,3.0.html I have also looked for this in fluent and i have found similar to this in a radition model which was define as "WALL_OUTER_TEMPERATURE(f,t)" |
please help UDF for velocity profile in y-directio | raju | Fluent UDF and Scheme Programming | 6 | April 12, 2019 23:21 |
UDF error - parabolic velocity profile - 3D turbine | Zaqie | Fluent UDF and Scheme Programming | 9 | June 25, 2016 19:08 |
defining temperature profile with UDF | mohammadkm | Fluent UDF and Scheme Programming | 11 | July 3, 2013 00:15 |
UDF temp. profile BC | Shashikant | FLUENT | 0 | June 24, 2006 03:16 |
temperature profile on boundary | sivakumar | FLUENT | 5 | November 24, 2002 00:58 |
