UDF temperature profile
Like Tree23Likes
Old   July 24, 2013, 07:04
flotus1's Avatar
Alex
flotus1 has a spectacular aura aboutflotus1 has a spectacular aura about
The code remains valid in this case. But as always, you should check if the temperature profile is correct before running your actual simulations.
No need to give me credits in your report for just a few lines of code.
daire6 likes this.
flotus1 is offline   Reply With Quote
Old   July 24, 2013, 08:32
sooraj
str6073 is on a distinguished road
i didnt check the profile. Can you please tell me how to do that also?? I googled it but got no positive results
str6073 is offline   Reply With Quote
Old   July 24, 2013, 09:41
flotus1's Avatar
Alex
Run a few iterations and look at a contour plot of the temperature at this boundary.
Old   July 24, 2013, 13:14
sooraj
thank you very much buddy. i wish i could return the favour somehow
Old   July 24, 2013, 13:38
sooraj
"Warning: explicit time-stepping not available. Using 1st-order dual-time. '' i get this msg while interpreting. calculation goes smoothly.you know what this mean??
Old   July 24, 2013, 14:40
sooraj
this is the contour i got . is this correct??
Old   July 24, 2013, 17:28
flotus1's Avatar
Alex
I have no idea why you get this message during interpretation of the UDF. What transient scheme do you use? Which kind of solver?
About the contour: provided the range is from 298K to 323K and the y-axis points from bottom right to top left, the contour is ok. Dont mind the artifacts at the intersection with the other face, they are mostly caused by the visualization.
Old   July 25, 2013, 01:22
sooraj
now there's no warnings. some mistakes from my part,i think.And about the contours, i think i need the variation in a vertical manner.bottom of the tank(cylinder) face should be blue above that green like ways. Can you modify like that??
Old   July 25, 2013, 03:13
blackmask will become famous soon enough
Kid, do your own work.
I lost my patience in this forum lately.
blackmask is offline   Reply With Quote
Old   July 25, 2013, 04:09
flotus1's Avatar
Alex
I cant. You are the only one who knows the orientation of your model. All you have to do is change the following line to match your requirements:
F_PROFILE(f, thread, position) = (tmin+tmax)/2.0 + (tmax-tmin)/d*x[1];
All the information you need can be found in this thread.
Old   July 8, 2014, 21:18
Unhappy Please please, need help.
  #31
Mohamed
B.Hamada is on a distinguished road
I'm VERY new to Fluent and I'm attempting to write a UDF that will make the heat flux at a wall a function of time. I've never programmed in C before either so I'm having some trouble getting the correct sytax
My function in Attach Files:
Please help me to witre it
I : Heat flux.
A : area of the front surface.
t : Time.
T : Temperature.
h : heat transfer coefficient.
\DeltaX : depth.
Cp: specific heat
\rho: density.
B.Hamada is offline   Reply With Quote
Old   July 10, 2014, 07:42
David
GM_XIII is on a distinguished road
I : Heat flux.
t : Time.
T : Temperature.
\DeltaX : depth.
Cp: specific heat
\rho: density.
Here you have a little example (first result from google)
http://bytes.com/topic/c/answers/866...ube-surface-3d
In your case if the heat flux doesn't depend of the position of the face in the boundary, it is even simpler. Something like this:
  1. #include "udf.h"
  2. /* profile for heat flux*/
  3. DEFINE_PROFILE(heatflux_profile, t, i)
  4. {
  5. /* declaring variables */
  6. face_t f;
  7. real area=0;
  8. begin_f_loop(f, t) /*This loop calculate the area of the boundary*/
  9. {
  10. area=area+NV_MAG(f);
  11. }
  12. end_f_loop(f, t)
  13. F_PROFILE(f,t,i)=YOUR EXPRESSION FOR I;
  14. }
The values of density, specific heat etc... can be found here:
http://aerojet.engr.ucdavis.edu/flue...udf/node90.htm
I dont know what depth in your model means, you shall give more information.
Regards
GM_XIII is offline   Reply With Quote
Old   July 10, 2014, 22:38
Mohamed
  1. #include "udf.h"
  4. {
  6. face_t f;
  7. real area=0;
  9. {
  11. }
  14. }
Regards
Thank you for your help.
About my problem, I'll explain. I treat the solidification of a material phase change in a photovoltaic system, a picture attachment allows you to know all the included in the model used to determine the heat flux exerted on the photovoltaic system variables.
Greetings
Old   July 11, 2014, 05:14
David
Greetings
Thanks, what i still cant understand is how do you get Tpv, can you attach a scheme of your domain and BV?
Old   July 11, 2014, 07:29
Mohamed
Please, I did not understand, for your question about the domain scheme and BV?
Old   July 11, 2014, 13:36
David
I asked if you could attach a simple sketch of your geometry and boundary conditions
Old   July 11, 2014, 22:20
Smile
  #37
Mohamed
Hi
An image attached shows geometry and boundary conditions.
Thank you so much.
Old   July 12, 2014, 10:56
ghost82's Avatar
Rick
ghost82 will become famous soon enough
What is Tpv? It's the mean of temperature in the pcm domain or a specific temperature in a specific point?
For Tpv(t-deltat) you could try to use C_T_M1(c,t), which returns the cell temperature value of the previous time step.
In your equation consider "t" as "t-deltat" and "t+deltat" as "t".
Try to start writing some code.
Daniele
ghost82 is offline   Reply With Quote
Old   July 12, 2014, 11:13
Mohamed
Daniele
Tpv It's the mean of temperature photovoltaic layer domain.
T_{pv,t} The temperature of the photovoltaic panel at the instant t.
T_{pv,t+\Delta t} The temperature of the photovoltaic panel at the instant t+\Delta t
Old   July 12, 2014, 11:21
ghost82's Avatar
Rick
Ok, but since we cannot read the future you can only evaluate temperatures at time t and t-deltat and not deltat+t.
Again, start writing some code, someone will help you to go through your code.
Daniele
please help UDF for velocity profile in y-directio raju Fluent UDF and Scheme Programming 6 April 13, 2019 00:21
UDF error - parabolic velocity profile - 3D turbine Zaqie Fluent UDF and Scheme Programming 9 June 25, 2016 20:08
defining temperature profile with UDF mohammadkm Fluent UDF and Scheme Programming 11 July 3, 2013 01:15
UDF temp. profile BC Shashikant FLUENT 0 June 24, 2006 04:16
temperature profile on boundary sivakumar FLUENT 5 November 24, 2002 01:58
