Xinquan
Rep Power: 13 ![]() |
Hi folks,
I was trying to load some UDFs into Fluent. However, this error always pops up. The UDF library you are trying to load (libudf) is not compiled for 3ddp on the current platform (win64). The system cannot find the file specified. The author of these UDFs told me the code is for win32. I am not 100% sure what it means. I do have a MSVS as the compiler, and it is a 32-bit one. The fluent 14.0 is 64-bit. I am using win 8 64-bit. I tried every solution I could find on the web: change the environment variables; install a SDK; edit the path; But I just could not fix the problem. Is there anyone helping me out here? Thank you. |
#2 | |
Ehsan Asgari
Rep Power: 18 ![]() |
Goodluck. |
problem loading UDF library in parallel cluster | Veera Gutti | FLUENT | 8 | July 26, 2016 07:24 |
UDF issues | ehooi | FLUENT | 4 | May 13, 2011 05:21 |
loading udf in parallel sytem | tahere | FLUENT | 5 | December 13, 2008 01:17 |
problem loading UDF in parallel fluent | Tim | FLUENT | 12 | July 12, 2008 12:59 |
Problems with loading udf | Mukund | FLUENT | 6 | July 6, 2004 02:13 |
