Gerry Boyce
Rep Power: 13 ![]() |
Hi there,
I was wondering if someone could help me with a problem I am having regarding defining a wall surface reaction UDF. I am trying to model platelet transport in blood and platelet interaction with blood vessel walls. I have defined two platelet species (gas species), Resting Platelets (RP) and Activated Platelets (AP). I have a source term for each of the species and I am trying to define a reactive wall flux term that accounts for platelet deposition on the vessel walls. In the DEFINE_SR_REACTION macro, I have defined 2 wall surface reactions - reaction-1 for RP flux to the wall and reaction-2 for AP flux to the wall In the UDF I am returning a reaction rate value in the pointer *rr (kmole/m^2-s) In the Edit Reactions dialogue box (Problem Setup -> Materials -> mixture-template -> Reactions-Edit) I have set the following parameters: reaction-1: Reactant Specie = RP, Stoic. Coeff. = 1, Rate Exponent = 1 Product Specie = RP, Stoic Coeff. = 1, Rate Exponent = 0 reaction-2: Reactant Specie = AP, Stoic Coeff. = 1, Rate Exponent = 1 Product Specie = AP, Stoic Coeff. = 1, Rate Exponent = 0 When I run the model I see no flux of AP or RP to the wall surface and I'm not quite sure what I'm doing wrong. Any help would be greatly appreciated! Thanks! |
Tim Maguire
Rep Power: 16 ![]() |
Gerry:
Did you end up finding a solution to this problem? |
SSL
Rep Power: 14 ![]() |
I have modeled so many combustion problems. What is the problem. He may have not written the UDF correct.
surface reaction, porous media | Ali | FLUENT | 2 | March 31, 2016 17:26 |
[Gmsh] Problem with Gmsh | nishant_hull | OpenFOAM Meshing & Mesh Conversion | 23 | August 5, 2015 02:09 |
Wall Surface Reaction!!!! | ansonkuo | FLUENT | 0 | December 24, 2007 02:15 |
wall surface reaction | Razvan | FLUENT | 0 | April 5, 2005 05:10 |
chemical reaction - decompostition | La S. Hyuck | CFX | 1 | May 23, 2001 00:07 |
