mass fraction gradient macro error
Old   January 9, 2013, 11:12
Default mass fraction gradient macro error
Daniel Sebastià Sáez
danielet82 is on a distinguished road
Hi there guys,
in my case, I am trying to define a mass transfer coefficient with the following DEFINE macro:
DEFINE_MASS_TRANSFER(liq_gas_source, cell, thread, from_index, from_species_index, to_index, to_species_index)
Inside the UDF I need to define the gradient of the mass fraction of a species with...:
C_YI_G(c,t,i)
When I try to interpret the UDF the next error message appears:
Error: C:/Users/Dani/AppData/Local/Temp/mass_trans_rate.c.7.c: line 14: t: undeclared variable
I think that the fact that "t" doesn't appear in "DEFINE_MASS_TRANSFER(liq_gas_source, cell, thread, from_index, from_species_index, to_index, to_species_index)" has something to do with it.
Does anybody know how can I fix it.
Thanks in advance
Daniel
danielet82 is offline   Reply With Quote
Old   January 10, 2013, 02:55
SSL
msaeedsadeghi is on a distinguished road
Do not use C_YI_G(c,t,i), change the parametersk c,t,i to cell, thread and ...
msaeedsadeghi is offline   Reply With Quote
Old   January 10, 2013, 05:10
wow, you're the best. It works. I mean no error message appears when it comes to interpret it and you can select it in the UDF list.
The problem arises when it comes to initialize the solution in order to run the solver. The next message appears:
"999999 (..\src\mpsystem.c@1149): mpt_read: failed: errno = 10054
999999: mpt_read: error: read failed trying to read 4 bytes: No such file or directory
MPI Application rank 0 exited before MPI_Finalize() with status -1073741819
The Parallel FLUENT process could not be started. "
Any hint or idea????
Old   January 10, 2013, 05:11
SSL
have you enabled saving gradiants?
set/solve/expert/...
Old   January 10, 2013, 05:54
ummmmm nope. Do I have to do that with a text command??
THanx
Daniel
Building OpenFOAM1.7.0 from source ata OpenFOAM Installation 46 March 6, 2022 14:21
[swak4Foam] installing funkySetFields igo OpenFOAM Community Contributions 1 November 20, 2012 21:16
Compile problem ivanyao OpenFOAM Running, Solving & CFD 1 October 12, 2012 10:31
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 20:08
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
