UDF dynamic mesh problem
Old   December 21, 2012, 03:46
Default UDF dynamic mesh problem
Gao
gaozhengyu is on a distinguished road
These 2 udf codes are both for the model I uploaded(one for membrane one for axis), and the membrane oscillated successfully.
The problem is the stretching of the axis.I want the point of the axis at (0,0) fixed. How should I do?
gaozhengyu is offline   Reply With Quote
Old   December 27, 2012, 02:18
Gao
I have solved the problem, the code is changed as below.
And the model is not the one I uploaded before so the number in the code is different.
DEFINE_GRID_MOTION(oscilliation,domain,dt,time,dti me)
#if PARALLEL
Thread *tf = DT_THREAD(dt);
face_t f;
Node *v;
real NV_VEC(vel);
real NV_VEC(del);
real xx;
real yy;
real width;
real period;
int n;
/* set deforming flag on adjacent cell zone */
SET_DEFORMING_THREAD_FLAG(THREAD_T0(tf));
//Message ("time = %f, omega = %f\n", time, sign);
NV_D(vel, =, 0.0,0.0,0.0);
width = 0.095776 / 2.0;
period = 0.05;
begin_f_loop(f,tf)
f_node_loop(f,tf,n)
v = F_NODE(f,tf,n);
xx = NODE_X(v);
if(xx>0.058)
if (NODE_POS_NEED_UPDATE (v))
NODE_POS_UPDATED(v);
yy = (NODE_Y(v)) / width;
vel[1] = 0;
vel[0] = - 2 * 3.14159 / period * 0.005 * (1 - pow(yy,2)) * cos(2 * 3.14159 / period * time);
NV_VS(del,=,vel,*,dtime);
NV_VV(NODE_COORD(v),=,NODE_COORD(v),+,del);
end_f_loop(f,tf);
#endif
Dynamic mesh & Negative volume in 3D mahzironrazak FLUENT 97 December 28, 2020 23:09
Dynamic Mesh UDF Jkl FLUENT 9 September 7, 2011 00:43
Problem related with UDF for dynamic mesh Ryan FLUENT 6 April 29, 2004 10:29
Problem related with UDF for dynamic mesh Ryan FLUENT 1 April 16, 2004 07:05
