UDS source term
Old   November 30, 2012, 00:55
Default UDS source term
Mukesh
er.mkumar is on a distinguished road
Dear all,
I need little help to write my UDS source term.
My equation represents reaction rate and is represented as:
(dX/dt) = k_a*e^(-Ea/(R_u*T))*((P_i - P_eq)/P_eq)*(1-X)
where,
X is concentration at any time instant 't' [0< X <1]
k_a is reaction constant
E_a is activation energy (Constant)
R_u is universal gas constant
T is temperature of cell
P_i is initial supply pressure (constant)
P_eq is equilibrium pressure (dependent on 'T') defined as
ln(P_eq) = (DELTA_S/R_u)-(DELTA_H/(R_u*T))
Here, DELTA_S & DELTA_H are again constants
R_u & T are as defined above.
I wrote this, But it doesn't seem to work properly as the temperature of my domain vary radially (an annular cylinder) and hence reaction rate is different at different radii, Ideally as 'x' reaches '1' reaction should stop but when I plot 'X' contours it shows values > 1 in colder regions (suggesting reaction continues even after reaching a value >1) as this should't be.
DEFINE_UDS_UNSTEADY(uds_time,c,t,i,apu,su)
	real physical_dt;
	real vol;
	real rho;
	real phi_old;
	physical_dt = RP_Get_Real("physical-time-step");
	vol = C_VOLUME(c,t);
	rho = 1;
	*apu = -rho*vol/physical_dt;
	phi_old = C_STORAGE_R(c,t,SV_UDSI_M1(0));
	*su = rho*vol*phi_old/physical_dt;
/* Kinetic Equation SOURCE term */
/* Convection & Diffusion part are zero */
DEFINE_SOURCE(uds_source,c,t,ds,eqn)
	real tp;
	real rate;
	real P_eq;
	real cond;
	tp = C_T(c,t);
	P_eq = pow(10,5)*pow(2.72,((DELTA_S/R_u)-(DELTA_H/(R_u*tp))));
	C_UDMI(c,t,0)= P_eq;
	cond = P_i/P_eq;
	if(cond>1)
		rate = k_a*pow(2.72,(-E_a/(R_u*tp)))*((P_i/P_eq)-1)*((C_UDSI_M1(c,t,0) - x_f)/(x_i - x_f));
		ds[eqn] = k_a*pow(2.72,(-E_a/(R_u*tp)))*((P_i/P_eq)-1)*(1/(x_i - x_f));		/* Derivative of SOURCE w.r.t. DEPENDENT variable */
	else
		rate = 0;
		ds[eqn] = 0;
	C_UDMI(c,t,1) = rate;
	return rate;
er.mkumar is offline   Reply With Quote
Old   December 6, 2012, 06:59
Default UDS source is not returning value to Energy source term
Mukesh
Someone please help!
What I figured out was my UDS source is calculating values for various cells but I guess it is not returning the values to energy source term.
What could be the reason.
Monitoring 'rate' (UDS source) shows variations spatially (as temperature is varying spatially) But this variation is not taken up by the Energy source term although it is directly dependent on the 'rate' (UDS source).
Please, please ......someone help me out.
Old   January 29, 2013, 12:51
Jeremiah Lin
weloveUDF is on a distinguished road
Maybe you could try using UDM to store "rate" and to obtain "rate" by reading UDM.
weloveUDF is offline   Reply With Quote
Old   January 31, 2013, 17:26
Mukesh
Hello Lin,
Sorry I didn't updated the status on my work. And yes you are correct to suggest using UDM. I solved the problem using UDM. Thanks.
Regards,
Mukesh
Old   January 14, 2014, 05:06
Long Nguyen
longbk is on a distinguished road
Hello Lin,
Regards,
Mukesh
Dear Mukesh,
I'm working on the model of hydrogen storage by metal hydride. So, I'm very confused about the UDF code for source term. Could you share with me your UDF code just for reference?
Thank you very much
Regards,
Long Nguyen
longbk is offline   Reply With Quote
source term, uds source
UDS source term units Ale FLUENT 3 March 29, 2017 08:08
friction forces icoFoam ofslcm OpenFOAM 3 April 7, 2012 11:57
lid-driven cavity in matlab using BiCGStab Don456 Main CFD Forum 1 January 19, 2012 16:00
Large source term in species equation MACFD FLUENT 4 January 4, 2011 15:16
UDFs for Scalar Eqn - Fluid/Solid HT Greg Perkins FLUENT 0 October 11, 2000 04:43
