Problem UDF for Turbulen viscosity
Old   October 26, 2012, 16:40
Default Problem UDF for Turbulen viscosity
Fer Villa
fevi84 is on a distinguished road
Hi all,
How i can retrieve variables of different domains inside the same macro? I have retrieve the liquid density value, gas density value and turbulent viscosity inside the same macro. I want set up the Turbulent viscosity in the secondary phase using "dispersed" as Turbulent Multiphase Model in the k-e model.
I tried with the following udf:
DEFINE_TURBULENT_VISCOSITY(mu_t_ke_air, c, phase_t)
Thread *mt; /* mixture or super thread*/
Thread **all_phase_threads; /* An array of all the phase threads */
mt = THREAD_SUPER_THREAD(phase_t);
all_phase_threads = THREAD_SUB_THRADS(mt);
/* all_phase_threads[0] is primary thread, */
/* all_phase_threads[1] first secondary phase thread */
real mu_tg;
real rho_l = C_R(c,all_phase_threads[0]);
real rho_g = C_R(c,all_phase_threads[1]);
real mu_tl = C_MU_T(c,all_phase_threads[0]);
mu_tg = mu_tl*rho_g/rho_l;
return mu_tg;
But, this udf gave the following erro:
THREAD_SUB_THRADS is an undeclared variable.
Anyone know why gave this erro. If anyone knows another way to do it, using other pointer, etc..., please tell me.
Thanks!!!!
fevi84 is offline   Reply With Quote
Old   January 17, 2017, 15:18
Ekta J
Ekta J is on a distinguished road
Hello, Does anyone know the correct udf for modifying turbulent viscosity in k-epsilon per phase model? (for Euler-Euler)
I am using the following udf (modified as per my knowledge, from the basic udf for k-epsilon mixture model) But it does not seem to be taking the correct value of k, epsilon etc from the fluent:
#include "udf.h"
DEFINE_TURBULENT_VISCOSITY(mu_t_ke_air,c,t)
real rho_g, KE_g, D_g, mu_t_g;
rho_g = C_R(c, t); /* gas phase density */
KE_g = C_K(c, t); /* gas phase Kinetic energy */
D_g = C_D(c, t); /* gas phase epsilon */
mu_t_g= 0.09*rho_g*KE_g*KE_g/D_g;
C_UDMI(c,t,2) = mu_t_g; // (Calculated above)
return mu_t_g;
Ekta J is offline   Reply With Quote
Old   June 25, 2017, 19:25
Vedamt Chittlangia
vcvedant is an unknown quantity at this point
Hi Ekta,
I face similar problem for implementing turbulent viscosity. Even though I am implementing the exact same definition as given in the equations for Re_y, Re_t, f_mu to implement User Defined viscosity for Lam-Bermhorst and Yang-Shih model but the results are quite different.
Any ideas?
Thanks
vcvedant is offline   Reply With Quote
Problem with divergence TDK FLUENT 13 December 14, 2018 07:00
UDF using problem, error happens-heip!! Michael FLUENT 1 December 9, 2008 08:51
Problem in compiling property(density) UDF satish2968 FLUENT 3 October 31, 2008 16:06
parallel UDF problem kerem FLUENT 2 June 20, 2006 07:56
Problem of Turbulent Viscosity Ratio Limited David Yang FLUENT 3 June 3, 2002 07:13
