October 26, 2012, 10:56 |
udf error
Krishna
Rep Power: 14 |
hello every1...
i am working on a journal bearing project on Ansys Fluent and for that I wrote a udf DEFINE_SDOF_PROPERTIES to define the load on the journal.. when i interpreted it 1st i found the nmake error..i installed microsoft visual basic and changed the environment variable..rerun it and tried to build the library found an error of missing libudf.dll i copied it from the Fluent folder to the project folder and then ran again..library build but now the udf doesn't appear in its place... was there anything wrong in my procedure..if not why cant i see the udf..?! plz help..thanx in advance.. |
Undeclared Identifier Errof UDF | SteveGoat | Fluent UDF and Scheme Programming | 7 | October 15, 2014 08:11 |
Problem with UDF compiling for kTkLW model | Wantami | FLUENT | 0 | July 18, 2011 06:11 |
ParaView for OF-1.6-ext | Chrisi1984 | OpenFOAM Installation | 0 | December 31, 2010 07:42 |
Installation OF1.5-dev | ttdtud | OpenFOAM Installation | 46 | May 5, 2009 03:32 |
Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 21:50 |
