Squeeze Flow
Old   October 25, 2012, 17:41
Default Squeeze Flow
Michael Anderson
mjaisit is on a distinguished road
I'm attempting to model simple squeeze flow between 2 plates. I have created a simple rectangle in 2D with axisymmetric geometry, but am having problems getting it to run. Below is the geometry for the file with the specified boundary conditions.
[IMG] http://s3.beta.photobucket.com/user/...ryPic.png.html [/IMG]
I was told by customer support that I need to create a udf, define_cg_motion so I am trying to figure this out as I am new to fluent. Below is the udf I made and interpreted into the setup for the top plate.
# include "udf.h"
# include "dynamesh_tools.h"
DEFINE_CG_MOTION(wallmov, dt, vel, omega, time, dtime)
Thread *t;
face_t f;
vel[1]=.1;
I specified the system as a transient system with a .001sec time step and to run for 50 time steps.
Without the udf I am getting incorrect results and no visible motion of the top plate. When I try to specify the cg_motion for the top wall i am getting the error: Warning incorrect cg motion UDF wallmov on zone 7 (assuming no motion).
If anyone could help, it would be much appreciated because I have been struggling on this for awhile. Also if the problem is nearly clearly defined please let me know.
Thanks in advance!!!
mjaisit is offline   Reply With Quote
Old   October 26, 2012, 03:41
ghost82's Avatar
Rick
ghost82 will become famous soon enough
you have to move your plate in -x direction!
vel[1] is movement in y direction, with vel[0] you will move your plate in x direction; I think you have to specify a negative velocity to move in -x direction; vel[2] is movement in z direction.
Try this:
# include "udf.h"
Thread *t;
face_t f;
vel[0]=-0.1;
vel[1] = 0.0;
vel[2] = 0.0;
Very important:
you have to compile this udf, interpreting it will not work with cg motion macro!
ghost82 is offline   Reply With Quote
Old   October 27, 2012, 16:13
Michael Anderson
Thanks so much for the help, I finally got it working!!!
I have one more question that should be simple but i cant find the answer anywhere. After previewing the mesh motion and the two walls converging how do I reset the geometry and mesh to the beginning? I tried to initialize the solution, but that only resets the iterations and time step and not the geometry. So when I try to run it again I get the error of a negative volume.
Thanks again!
Old   October 28, 2012, 05:14
ghost82's Avatar
Rick
Thanks again!
I think that after previewing the motion you cannot reset the position of the plate..I remember I read this somewhere in the past: save cas and dat files before previewing the motion!
Old   April 21, 2015, 07:42
Default bad convergence
rim
rimi is on a distinguished road
I'm a beginner in fluent and i'am trying to model a 2d version of squeeze flow between two disks. I made a simple rectangle(1x20) for the geometry in the xy axis and for the boundary conditions I specified the top as a outflow moving, the bottom as an axis , my left as symmetry and the right boundary conditions as velocity inlet (0.01 m/s).First of all I want to know if my geometry is convienient with my model ? Second in the simulation when i put a fine meshing i found a bad results and when i put a large mesh i found a good results and these are illogical .If anyone has any suggestions it would be greatly appreciated.
Thanks all.
rimi is offline   Reply With Quote
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
Different flow patterns in CFX and Fluent avi@lpsc FLUENT 4 April 8, 2012 07:12
Flow meter Design CD adapco Group Marketing Siemens 3 June 21, 2011 09:33
potential flow vs. Euler flow curious ... Main CFD Forum 23 July 21, 2006 08:40
Plug Flow Franck Main CFD Forum 3 September 4, 2003 06:57
