Segmentation Fault on F_C0, F_AREA, etc
Old   October 24, 2012, 16:24
Default Segmentation Fault on F_C0, F_AREA, etc
Salvador Ortiz
salvadortiz is on a distinguished road
I'm trying to write a simple code for computing gradients, but cannot get past a SIGSEGV signal at the " c1 = F_C1(f,t);" line. I also get this when trying to use F_AREA (but I can compute F_CENTROID).
Can anybody tell what is wrong here?
Thanks in advance
DEFINE_ON_DEMAND(gradientes)
real gx, gy;
Thread *t, *t1;
cell_t c, c1;
face_t f;
int n=0;
real NV_VEC(A), NV_VEC(xxx), surf;
FILE *fout;
Domain *d; /* declare domain pointer since it is not passed as an
argument to the DEFINE macro */
d = Get_Domain(1); /* Get the domain using ANSYS FLUENT utility */
/* fout = fopen("faces.dat", "w"); */
fout = fopen("pressgrad.dat", "w");
thread_loop_c(t,d) /* Loop over all cell threads in the domain */
begin_c_loop(c,t) /* Loop over all cells */
gx = gy =0.;
c_face_loop(c,t,n) /*loopsoverallfacesofacell*/
f=C_FACE(c,t,n);
/* if (f) F_CENTROID(xxx, f,t); /\* AREA(A, f, t); *\/ */
/* fprintf(fout, "Cell %ld\tFace %d: %ld\t %g %g\n", c, n, f, xxx[0], xxx[1]); */
c1 = F_C1(f,t);
if (c1==c) c1 = F_C0(f,t);
F_AREA(A, f, t);
t1 = C_FACE_THREAD(c1,t,n);
if (t1==NULL) {
gx += (C_P(c,t))*A[0]/2.;
gy += (C_P(c,t))*A[1]/2.;
} else {
gx += (C_P(c,t)+C_P(c1,t1))*A[0]/2.;
gy += (C_P(c,t)+C_P(c1,t1))*A[1]/2.;
surf = C_VOLUME(c,t);
C_CENTROID(xxx,c,t);
fprintf(fout, "%g %g %g %g %g %g %g\n", xxx[0], xxx[1], C_P(c,t), C_P_G(c,t)[0], C_P_G(c,t)[1], gx/surf, gy/surf);
end_c_loop(c,t);
fclose(fout);
salvadortiz is offline   Reply With Quote
fluent, f_area, f_c0, sigsegv, udf
Segmentation fault when running dieselFoam or dieselEngineFoam in parallel francesco OpenFOAM Bugs 4 May 2, 2017 22:59
segmentation fault when installing OF-2.1.1 on a cluster Rebecca513 OpenFOAM Installation 9 July 31, 2012 16:06
Segmentation Fault Shawn_A OpenFOAM Running, Solving & CFD 6 October 31, 2011 15:38
forrtl: severe (174): SIGSEGV, segmentation fault occurred therockyy FLOW-3D 7 January 19, 2011 23:52
ParaView segmentation fault only for multiphase gwierink OpenFOAM 9 March 25, 2010 08:23
